Old 02-16-2010, 12:08 PM
Tmitch is on a distinguished road
Question Help identify a Bridgeport mill
I have a Bridgeport mill which I am trying to identify and get a parts breakdown for.
The base is, I believe, a Series II ex CNC machine, SN T-775. It has an air assisted knee. It has been converted to a manual machine and the head has been replaced with a Series I, 2HP, verispeed.
Old 02-16-2010, 02:13 PM
Moderator
machintek is on a distinguished road
the T usually stands for a T ram which typically had more than 1 head on it or a head and a tracer valve. Box ways or dovetail ways? Air assist on the knee?
George
Old 02-16-2010, 04:01 PM
George
I would call the ways "Box", as they are square and chromed. Yes, it does have air assist on the knee.
I am trying to get a parts breakdown, because I inadvertently ran the table (y axis) up against the rear stop while installing a power feed and now the ball screw is moving back and forth about a .1 inch play (less than 1/4 turn). I can't figure out what is supposed to prevent the ball screw from moving back and forth.
Old 02-16-2010, 09:23 PM
polaraligned is on a distinguished road
The angular contact bearings right in the front of the knee. Put a dial indicator on the end of the ballscrew and see if the ballscrew itself is moving when you turn it. If so, the problem is in the ballscrew support bearings, if not moving, look for worn ballscrews or maybe loose screws on yoke that attaches to saddle.
Old 02-16-2010, 11:06 PM
JimPAC's Avatar
JimPAC is on a distinguished road
BRIDGEPORT IRON!
Take A picture Send it to me and I'll tell you exactly what you have and where to find parts!
BP IRON IS GOOD!
Old 02-17-2010, 09:24 AM
Yes, the ballscrew is moving back and forth about .1inch, as it is turning. I don't need a dial indicator to see that. It didn't do that before I hit the rear mechanical stop with the new table feed. There must be a stop to prevent the back and forth play of the ball screw that slipped. I can see a brass sleeve at the front of the ball screw (looking up from under the table) with a set screw. Is this the stop?
Old 02-17-2010, 09:32 AM
BP IRON IS GOOD!
This picture shows the mill with a Supermax head, which I am replacing with a "real" BP head.
Name:	P4030001 (Large).JPG‎
Old 02-17-2010, 10:13 AM
JimPAC's Avatar
Tmitch,
This looks like a series II CNC and it has been converted to conventional.
There is no mechanical stop because it originally used limit switch's!
The play in your travel is probably due to a broken retainer sleve!
You will need to istal limit switches for your power feeds to prevent any more damge from occuring.
I'll send you my guy for parts contact info and he'll tell you how to repair your Series !! BP Jewel.
And for heavin sake paint that thing a different color.
Hope this helps
Jim
Old 02-17-2010, 01:59 PM
Tmitch,
Jim
Where is this retainer sleeve? Is it on the front or rear of the ball screw???? It sounds like, it is the one I can see from underneath with a set screw on the front of the ball screw. It doesn't look broken, but may have been moved slightly away from the bearing (I hope).
Yes, I have now installed limit switches (too late) on the table feeds.
Come on, Green is beautiful.
My new (old) head is a series I, 2HP verispeed. At least now, the whole mill is Bridgeport.
Old 02-17-2010, 03:55 PM
Sparky_NY is on a distinguished road
The retainer sleeve he is speaking of is located behind the crank handles and other hardware, on the outside. It holds the 2 bearings into their bores. It is a round ring with 3 allen screws. The ring itself is made of that real cheap pot metal and the screws pull through very easily. The best thing is to make a replacement with decent metal/aluminum but if you get another original be very carefull not to tighten the screws very much or they will also pull through.
  #11   Ban this user!
Old 02-17-2010, 07:30 PM
advt001 is on a distinguished road
Polar what are you going to do with the Supermax head?If for sale how much?
  #12   Ban this user!
Old 02-18-2010, 08:51 AM
Yes, it is for sale. Would have to be shipped from Oklahoma. It works, and is complete, but it is noisy. Don't know why, I replaced the timing belt not too long ago. Would $1000 be too much (you arrange and pay for shipping).
Identify this Bridgeport head? supermatttheher Bridgeport and Hardinge Mills 1 01-24-2010 08:57 PM
Need Help!- Help Identify this mill Mogal General Metal Working Machines 2 07-13-2008 03:28 PM
Newbie- can anyone identify this bridgeport water Bridgeport and Hardinge Mills 2 07-01-2008 01:14 PM
can anyone identify this mill jvetters General Metal Working Machines 4 11-29-2007 02:15 PM
What Mill? Bridgeport or... Com General Metal Working Machines 3 12-26-2005 04:48 AM
