Hi All, I've been playing with my Interact Series 1 Mk 2. I love it. It may not be perfect, but it's done everything I've asked it to do. I've run in to a few quirks, but most are solved now. Not this one... So I enter a program and I could run in line by line. Then when there is an error I can edit the program and just continue. Or I can go to manual and turn off the spindle, then reload the program ... If I go to run full sequence and the program starts and then I see a problem what can I do? If I hit the small red button (sequence stop maybe?) the machine pauses but the spindle keeps spinning. I can hit the green one and things start up again. What I want to do is stop the execution. The only way I've been able to do it is with the emergency stop and that sucks. At 500 rpm it's not so bad to here the electric brake stop the motor, but at 4000..... I always pause the program before the emergency stop, but it still has to engage the brake... all I want to do is stop the spindle nicely, edit my program and run it again... Any one have a solution? If your thinking write better programs... yeah but I still make mistakes... sometimes it's just the repeat is too large and I could stop it at 10 passes not 11... Thanks |
| I'm actually using the machine in ISO mode, not conversational so I have the add-on key pad that attaches magnetically to the TNC control panel. Stop is now "D" so I didn't see that there was a stop button. In the manual, which I just saw now, the stop key in ISO mode is the "del" key. I haven't had a chance to try it yet as I was repairing the z-axis today. I'm sure it will work and I didn't see the stop button because there isn't one with that label in ISO mode. Thanks again for the help. I think this is another solved issue! Brian Last edited by MeTri; 02-14-2010 at 09:43 PM. |
| BOSS 8 EMC boot sequence | jonny | Bridgeport and Hardinge Mills | 2 | 04-02-2007 09:00 PM |
| cut sequence | camtd | Surfcam | 2 | 06-13-2006 11:26 AM |
| Sequence #'s | Mountainwildman | Post Processors for MC | 2 | 04-02-2006 11:25 AM |
| Wire sequence? | scratch_6057 | Stepper Motors and Drives | 3 | 03-30-2006 07:33 AM |
| Power up sequence | Konstantin | General Electronics Discussion | 1 | 10-05-2004 05:05 PM |
