03-23-2010, 12:14 AM
Originally Posted by nate whats the best way to tap a bunch of 1/4-20 holes in aluminum with a 3 axis BP conversion? some blind, some through.
can a tapping head be used with my Z axis? is their a tapping head that will allow me to just program Z down, go to depth and then z up for the retraction? will the movement in the z not allow the tap head to "pull" the tap into the metal as it is designed to do?
I dont have manual control of my Z anymore, so I need to fnd a way to use a tapping head in an automated manner.
Any thoughts? |
I used a Procunier 15000 CNC tapping head for this type of work. (I think maybe the 1/4" and up needs the 16000 model.) It is a pressure-operated forward/reverse clutch. When you push the tap forward, it engages the forward clutch, when you pull back, it engages a 2:1 reverse clutch. So, you calculate the correct feed at whatever spindle speed you select, feed Z to required depth, then retract at twice the forward feedrate. If the feed is a little lower that the exact number, the clutch will slip a little to allow the Z feed to catch up. (If the feed is too fast, ouch, it mashes the tap!)
The only problem with this is the thing is so LONG, the tap is about 8" from the spindle nose.
I used this with spiral flute taps, and it worked quite well, I could tap holes all day long. I made some fixture plates with 144 10-32 holes in less than an hour, spotting, drilling and then tapping the holes. You can also run combined drill-taps with it, although the lack of stiffness may make hole position a bit loose.
Jon |
