Old 02-06-2010, 06:07 PM
salvador781 is on a distinguished road
need help with toolchanger bridgepor 412
need help with the tool chager bridgeport interact 412
with hendenhain control
the screen display :"tool changer not counting"
already check the magnetic sensor and working properly
thanks
for your help
Old 02-06-2010, 09:47 PM
Moderator
machintek is on a distinguished road
There may be 2 switches. One to find tool one and one to count. Just because the switch changes state, next you have to make sure the control sees it.
George
Old 02-07-2010, 03:38 PM
thanks for your help really appreciated did that and it did
work .....now the carrousel works and find the rigth tool but the motion of pick up and drop the tool is not working
the spindle drops and pick the tool about 3 inches from where it suppossed to be
some time ago i lost the parameter of the machine and i had to get new parameters ,,,i upload them and the machine works ,,,but then i find that i had the parameters
and i compare with the one that i got from other source and some of them where modified i mean in the one that
i had in the first place ,,,,, do you think that might have something to do for not doing the pick up and drop motion
thanks
sal
Problem- tm1 toolchanger veets1 Haas Mills 3 01-28-2010 10:38 AM
diy toolchanger??? marcerasmus Wood Working Tooling 2 10-07-2007 11:24 PM
cnc DIY toolchanger??? marcerasmus CNC Tooling 1 10-07-2007 04:30 PM
cleaning a gunked up bridgepor lesnesman Bridgeport and Hardinge Mills 16 05-26-2006 08:30 PM
