Old 02-05-2010, 07:17 AM
Summeren is on a distinguished road
Program comment TNC155 ISO
I am using a Bridgport Interact 412 (1987) with a Heidenhain TNC 155 Control.
I use the ISO language.
The problem is this: I want to add comment to my program lines (or between them) so I can store information about tools I use, etc.
It is not even a problem if this comment disapears after sending it to the machine, it's just that I have the comment in the programs on my computer.
Does Anybody know how to do this???
Old 02-05-2010, 02:55 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Heidenhain Comments
Try putting comment after a semi-colon ;
Newer Heidenhain controls will read this, older ones may not. If it does read the program it will discard the comment.
DP
Old 02-06-2010, 02:20 AM
Thanks a lot. That did the trick.
If I knew it was that simple.....
Tags
comment, heidenhein iso, iso, tnc155
Posting GibbsCam to TNC155 ISO hartan Post Processor Files 0 10-10-2009 06:34 AM
Bridgeport TNC155 with EMC2? dbcooper99 LinuxCNC (formerly EMC2) 0 12-15-2007 02:34 PM
TNC155 Testing PL100 RichardCop General Metal Working Machines 7 02-22-2007 07:59 PM
Need help with a Heidenhain TNC155 Post!!! Kim Post Processors for MC 3 11-09-2006 02:31 AM
Still struggling with the Heidenhain TNC155 plane magic Bridgeport and Hardinge Mills 3 10-26-2006 05:07 AM
