| Ez Trak backlash adjustment Does anyone know how to adjust the backlash on a ez-trak mill? I would guess that the ballnut can be adjusted. If this true, any specs for torque or preload and how to measure. Thanks. |
| I have never fooled around with the ball nut. Anytime it is too loose, the ballscrew gets regound and bigger balls are loaded. I installed a few machines at a place called National Precision in Franklin, TN. That is his business. He rebuilds ball screws. To adjust backlash, I increase the value in the machine by .002 inches. I then machine a circle in aluminum with a spring cut. Now sweep the circle with a dial indicator. The steps you measure are how much it is overcomped. Subtract this value from what is in the machine. If it varies at 3 and 9 oclock, then your X ball screw is worn unevenly. You may want to average the compensation. Ditto for the Y. To get to the backlash value, at the main screen, press the * key, the key word is 11235 followed by enter twice. Do not forget to save. If a ball screw is replaced or reground, the existing pitch error comp values are worthless. George |
| Don't forget to check for looseness and/or wear in the ball screw support bearings. An overly tightened or improperly adjusted gib (did it myself) can also cause "backlash" problems Our of tune servo amps will further contribute to non linear servo performance. |
| Ballscrew Basics | Swede | Linear and Rotary Motion | 94 | 09-06-2011 07:23 PM |
| Backlash with worm drives ? | andy_ck87028 | Mechanical Calculations/Engineering Design | 9 | 02-02-2005 05:40 AM |
| Leadscrew backlash nut issue. | jaydee116 | General Metal Working Machines | 5 | 12-13-2004 07:57 PM |
| Backlash comp: does other axis pause during? | lesd | General CNC (Mill and Lathe) Control Software (NC) | 6 | 11-30-2004 02:05 PM |
| Z axis backlash adjustment help sieg x3 | replicapro | Benchtop Machines | 0 | 11-07-2004 01:13 PM |
