BP-High-Priests..please help me with the following..... Been working on making PET blowing molds last 3 month, with very interesting and good results in terms of accuracy and surface finishing on aluminum. Machine is a BP-Series 2, ex Boss 6, rigid-ram and currently running under Mach-3, HillBillys BOB, all X,Y,and Z original finned stepper motors and boards yet,,,,, and Mastercam X3 for the CAD-CAM stuff, since 2006, with no visible problems... ![]() Right now machining the first half cavity for the future 1.5 liter container...and here is where the nightmare begins.... Never had any problem with the semi-finishing as well as the finishing machining process before, but at the "roughing" machining, and after 2 or 2 and a half hours running the mill, a sudden erratic and non programmed toolpath took place and ruined the stock of material...mostly in straight line and over X axis. At that moment, mill was running fine with all the stuff...plenty of propper coolant..spindle speed of 3200 rpm at 32 IPM (800m.m./min) aprox of feed rate with a down plunge step of no more than 0.040 each pass...suddenly and without any warning..X axis increased its routine and in straight line, towards the positive side in 1 inch and more, as I hitted the emergency-stop button. Checked and re-checked the program...simulated it once again...made some air cutting again....nothing wrong were found...end of story. Only thing I could noted -if this helps somehow- at that moment, was the X stepper motor temperature... after 2 1/2 hours of machining...you couldnt hardly put your hands on it, but remember, at that time, X motor was doing most of the job, due the block position along X axis...so Z and Y motor were only working for the plunge and the step-over. Comments will be higly appreciated.!!! (sorry about the bad english writing). Jerry7 Last edited by Jerry7; 01-27-2010 at 09:30 AM. |
| Thanks so far polaraligned.... Any hint in how to "avoid" this so called "noise" ????.....because been using the mill during last 4 years without real issues doesnt give me any peace of mind....at least after a crash like this. Could this have been happened due a lack of capacity of the original boards...?..- or because "too much" feed rate value (32 IPM) at that moment ?.... or an X over-heated motor ?...anyway....just wondering. Thanks again! Jerry7 |
| Just out of curiosity, you didn't happen to plug in or unplug any USB devices (specifically flash memory) immediately prior to the problem? The only time I have seen Mach behave this way, is when I plugged in a flash drive while in the middle of a run. Windows did the drive poll/auto start box bit, and Mach just kept on happily sending the z axis through the part, the spoil board, and a good .25"s into the table before my $60 Onsrud router bit exploded... Curiously enough, my BOB has a watchdog timer, and it was enabled and working, and it did not catch the problem. I am extremely careful about USB now, to put things gently. This may not have been the case for you, but it doesn't hurt to throw it out there. Later, Jason |
| Hola mariolizano, gusto en conocerte,,no esperaba ver una respuesta y/o consulta en español en esta zona...en fin...te agradezco nuevamente. Míra, todo los componentes son absolutamente los originales aún. Lo único que realizé a la fresadora fue anteponer una placa BOB (opto-isoladora o foto-aislante), entre la nueva pc q contiene el Mach3 y toda la electrónica original Textron del equipo, Así la opero desde el 2006 sin aparentes problemas. Sigo atento... Abrazo fraterno... Jerry |
| Interesting point, Jason. But definitively it wasnt my situation, in fact...mill was running continously during 2 or 2 and a half hours without been touching or disconecting anything. But from now Ill take care in dont touch or make any move with this kind of devices (USB)connectors during a program run. Be well. Jerry |
| Need Help!- Axis loosing steps | Vogavt | Benchtop Machines | 3 | 01-07-2010 11:01 AM |
| Taig CNC loosing steps again | diamondback21 | Taig Mills & Lathes | 6 | 05-25-2009 01:21 AM |
| Need Help!- BP series 1 loosing steps | bartL | Bridgeport and Hardinge Mills | 15 | 07-16-2008 12:55 PM |
| Loosing steps | Normann | Automation Technology Products | 6 | 10-15-2007 02:15 AM |
| Loosing Steps How to Check | Cartierusm | Mach Software (ArtSoft software) | 10 | 09-11-2007 06:26 AM |
