Old 01-21-2010, 03:30 PM
markhas is on a distinguished road
Bridgeport Atom PC
I just finished testing my new Mach 3 driven Atom PC. It works great!
I've been using a standard PC, Derek's (Hillbilly) breakout board, and Mach 3 on my mill for sometime. Last month my PC took and dive so I decided to try something different. Previously, I had the PC mounted in the side cabinet and I noticed a lot of vibration during heavy machining. PC circuit boards do not like this and indeed my motherboard is what ended up failing.
The Atom motherboard is only 7 x 8 inches. I have an ASUS AT3GC-I. My total enclosure size with hard drive and CD ROM is only 5 x 9 x 13 inches. I got all of the stuff online. The MB, Case and RAM only cost $190. I used the old hard drive and CD ROM.
In the photos you can see that I have a bracket on the side of the mill that contains the PC box and a mount for the monitor. The monitor mount is adjustable. I also have a swiveling pan for the keyboard.
Hopefully someone gets an idea from this for their own MOD!
ID:	98185   Click image for larger version
ID:	98186   Click image for larger version
Bridgeport DNC hmc710 Bridgeport and Hardinge Mills 9 02-08-2010 06:14 PM
Need Help!- Bridgeport 760-20 Richmaj General Metal Working Machines 0 08-24-2009 02:21 PM
Bridgeport INT 412 Jurek Want To Buy...Need help! 0 04-06-2009 10:35 PM
Atom Minor Mk III dcencer I.C. Engines 0 08-19-2007 07:22 PM
Which Bridgeport would you buy? Skyshark Bridgeport and Hardinge Mills 2 08-17-2007 11:32 PM
