We have a couple Mid 90's BP VMC1000/22, TNC 370, that have the Bosch z15 controller cards for the rotary table installed. Need some help in determining which rotary table to buy that will interface directly to these cards. Any and all info will be aprreciated. Thanks |
| I have one Bridgeport machine (760DX) that I installed with a rotary table. It is a Troykee but the key to all this is that it has a Siemens motor in it. George
| I have not been able to find a table with a Siemens motor on it so I'm thinking about changing the motor on one of the Tsudakoma tables I acquired recently. Can you give me some specifics for a motor that will work with the Bosch Z15 driver? I also need to buy a couple cable connectors to connect to the I4 socket on the distribution board. Are these unique to BP? Can't find any marking on them. Bob |
| I would 'think' any servo motor with similar specs to the old interact machines would work, what are they [not at work] 90 volts, with a 10 volt tach. encoder might be harder, if the 370 is looking at the signal. later controls have a lot of parameters for encoders you you might be able to adjust |
| How do you use a rotary table? | ranchak | General Metal Working Machines | 0 | 01-30-2008 10:30 PM |
| Rotary table | Piobaire | HURCO | 0 | 08-22-2007 07:30 AM |
| HELP selecting MOTOR size 1 AXIS 8 ft table with load 1000 lbs | cjchands | Mechanical Calculations/Engineering Design | 1 | 08-07-2007 08:27 PM |
| Help hooking up Hypertherm 1000 to Plasmacam table... | dsmdude | CNC Plasma and Waterjet Machines | 1 | 03-29-2006 09:28 AM |
| Useful for Rotary Table? | Ken Stuempge | Mechanical Calculations/Engineering Design | 2 | 02-12-2006 09:16 AM |
