Old 01-20-2010, 12:36 PM
Shanghyd is on a distinguished road
Gross Positioning Error
I have a bridgeport intgeract II. I'm getting a gross positioning error lately.
The z axis servo will buzz and the gear will shake back and forth. Then the machine will quit with that error.
Resistance in the z axis servo is low compared to the y axis.
I've taken off the servo and cleaned the carbon deposits from the housing. I checked the brushes and they seem okay. Still plenty of brush left on all 4.
The commutator had a groove where the brushes run. I couldnt get a good idea of how deep the groove was but I could see a groove. I didn't pull the armature all the way out.
Any suggestions about troubleshooting this servo?
The machine is working fine right now but can error out at any time.
Old 01-20-2010, 04:20 PM
gus gus is offline
gus is on a distinguished road
re
likely a tach error, have you adjusted the trailing error?
Old 01-20-2010, 08:49 PM
Moderator
machintek is on a distinguished road
Is there a letter after the gross positioning error?
George
Old 01-21-2010, 07:33 AM
The letter was either a B or 8. My monitor is blurry sometimes.
The problem got worse. The machine errored out and the electrical box started smoking. I found a large black burned spot on the driver board. Now the z axis just dives towards the table and stops when it reaches its travel limit.
I either need a new driver board for the z axis or try to replace the bad components.
Gross Position Error Mike Conboy Bridgeport and Hardinge Mills 18 06-15-2009 03:38 AM
Bridgeport Interact 4-Gross Positioning Error foolmaker Bridgeport and Hardinge Mills 7 01-15-2009 03:13 PM
HELP! Gross positioning error crazeekev Bridgeport and Hardinge Mills 6 09-09-2008 10:11 AM
320 Positioning Error elogicca Gecko Drives 2 07-08-2008 11:33 AM
Bridgeport VMC308 - Gross Position Error mcwmah CNCzone Club House 7 11-09-2007 03:34 PM
