Old 12-28-2009, 11:32 PM
Kerry Harrison is on a distinguished road
Tips on a really nice side milled finish in aluminum
Greetings,
Anyone have any tips on how to achieve a nice smooth finish when side milling 6061 aluminum?
I have a Lagun vertical mill (BP clone) converted to CNC with ballscrews. I can't for the life me figure out how to get a really nice smooth finish when side milling. I have tried many different kinds of end mills and lots of speeds and feeds and I just can't seem to get a super smooth finish.
Any thoughts?
Thanks,
Kerry Harrison
Old 12-28-2009, 11:44 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
I lean toward hi helix for getting good finishes
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 12-28-2009, 11:45 PM
HimyKabibble is on a distinguished road
Originally Posted by Kerry Harrison View Post
Greetings,
Any thoughts?
Thanks,
Kerry Harrison
Try a 1/2" 2- or 4-flute HSS endmill, 3200 RPM, 12-15 IPM feedrate, with a 0.005"-0.010" radial depth of cut. If that doesn't give a nice finish, then either you're using crappy tools, or something is wrong with the machine (spindle runout, loose bearings, backlash, loose gibs, etc.). Use good quality endmills, not Chinese crap. The Putnam, Greenfield and Accurite from Enco and MSC are very good for the money.
Regards,
Ray L.
Old 12-29-2009, 07:19 AM
HuFlungDung's Avatar
Moderator
If you were to post a clear photo of the finish you can achieve at present, it might assist with diagnosis of the problem.
Cutter runout creates a scalloped appearance.
Conventional versus climb milling = poor versus good finish.
Wet cutting will produce a better finish. Continuous coolant during heavy cutting, or a spray film during light finish cutting helps.
Use a virgin tool that has not been used on other metals or for roughing. The tool should be sharp enough that it is dangerous to touch the cutting flutes. Uncoated is sharper because the coating tends to encapsulate the cutting edge which produces a radius over the cutting edge.
Old 12-29-2009, 08:28 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
3 Flute 40 to 45 Degree Helix ZrN Coated.
Harvey Tool Coating List Below. Comes in Handy
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 12-29-2009, 09:29 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Check out the end of this video. I used a pretty plain 3/8" 4 flute end mill. Feeds, speeds and DOC are shown on the vid. It is showing brass, but did aluminum parts the same way with nice results.
Lee
Newbie- Tooling for Getting a nice finish in Wax 8922uid CNC Tooling 3 08-26-2009 01:43 PM
Just can't get any sort of good finish boring aluminum on lathe - tips? SRT Mike General Metalwork Discussion 22 06-30-2008 11:42 AM
Rather nice finish on Aluminium :) ImanCarrot General Metal Working Machines 7 02-06-2007 10:37 AM
How to get a nice finish in aluminum? Zumba Mass finishing equipment/media/stratigies 7 04-26-2006 06:50 AM
Getting a nice finish on aluminum? SRT Mike General Metalwork Discussion 19 11-19-2005 01:00 AM
