Old 12-27-2009, 08:41 PM
bherr is on a distinguished road
Question General machining question
I'm running a BP Series II Interact 4 and was milling some hot rolled steel bars. I had to cut a 1.1880 deep channel, .333 wide and was using a .025 offset cutting saw with carbide ends. I had the 1.5 X 1.5 steel jigged up and was milling the channel at a 150 RPM's at a 8 feed rate and taking a 0.0250 depth of cut. the problem was that it took almost 2.5 hrs of milling time to cut to the depth. I tried running at higher RPM's (300) and a 14 feed rate but this burned the blade. Not having much experience working with steel I was hoping that I could get some advice as to the proper speed and feed rates to get a faster work time. I went thru 3 cutter blades to cut just 8 units. the cutter blades were 5 inch diameter.
thanks in advance for the help.
ben
Old 12-27-2009, 09:13 PM
HimyKabibble is on a distinguished road
ben
RPM should be calculated based on SFPM, which is typically 80-100 for HSS tools in mild steel, and 2-3X that for carbide tools:
RPM = 4 * SFPM / ToolDiameter(in inches)
In this case, you should've been running about 120-180 RPM, so you were OK with your initial setting.
Feedrate is based on RPM, chipload per tooth, and number of teeth:
Feedrate(in IPM) = RPM * #Teeth * Chipload
Chipload should really be gotten from the tool manufacturer, but if in doubt, figure 0.001-0.002"/tooth for all but small cutters (under 1/8" or so). So, if your saw had, say, 32 teeth, you'd want to run about 5 IPM.
Depth of cut can be set to whatever you can get away with, limited by spindle power, machine rigidity, and cooling. G too deep, and the spindle will slow down, and/or surface finish will deteriorate, and/or the tool will start to heat up. If any of these happen, back off on depth, or feedrate. But, it's best to find a feedrate that works well, then set depth to what the machine will tolerate.
So, overall, your RPM was probably OK, feedrate perhaps a bit high, and depth of cut probably low, unless you were running with no, or inadequate, coolant. Coolant is critical for something like this.
Regards,
Ray L.
Old 12-27-2009, 10:37 PM
Why did you not use a 5/16" end mill?
Old 12-28-2009, 05:34 PM
Regards,
Ray L.
Thanks much Ray, Great info.
ben
Old 12-28-2009, 05:37 PM
I actually tried the 5/16 end mill, but had trouble holding the tolerances once the end mill got down below .5. started going out of tolerance.
ben
Old 12-28-2009, 05:42 PM
ben
When cutting a slot, you need to use a smaller endmill, cut a slot down the center, then come back and do the sides. With a small endmill, and a deep slot, you need to take several light finish passes, to avoid tool flex. For these light passes, increase RPM about 30%, and reduce feed by 30-50%, for better surface finish.
Regards,
Ray L.
general pricing for prototype machining timmydabull General Business Practices and Pricing 18 08-21-2008 05:48 PM
general wood machining cnc questions matthewsutton Commercial CNC Wood Routers 1 03-20-2008 06:38 AM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
General Machining Question: rhino Mechanical Calculations/Engineering Design 6 07-22-2006 09:18 PM
How do I make these things? (General machining questions) CNC Brute General Metal Working Machines 2 03-03-2004 10:12 PM
