i have a series one boss 5 mill. i want to change the drive system to solid pullys and a electronic varible speed controller. can anyone tell me what size pullys and tensiner and where to order them from.it has the adjustable pullys with the mill now and it is to weak this will be the 3rd rebuild. thanks alex |
| Not to be rude, but if its the third rebuild, isint that telling you that you are exceeding the capability of the bridgeports head? Mabie you should look at upgrading the mill to a more robust unit. Also, I'm curious what kind of work you are doing that eats the variable speed parts?
__________________ Nate. Ann Arbor Meechigan |
| Regards, Ray L. |
| I wish I did have "info to offer" I was simply pointing out that if the machine "as built by the factory" is not sufficient, then looking at a different machine may be in order. That said, i'm all for modifying the machines I own when needed...
| Hi alex 850 nate the variable speed drive is not the greatest in these heads with the plastics bushes can wear out quite quick alex it's not that hard to change, what you want to do, the most problem you have is to tension the belt there is almost no ajustment, so you have to add some by sloting the flange of the motor mount,I will post some photos on here you can also see them in my photo gallery
__________________ Mactec54 |
| Hi alex 850 Here are some photos, you won't have to do your head like this, these were special heads I built for some customers, the heads have 5" taken out of the top so it will look different to your head, the motor shaft you can see that has 3.250 off this one I could of taken 1'' more off it but I was going to make some more pulleys for higher speeds, I did do one that runs at 12,000 this one runs at 6,000 so the extra pulleys are 2-1 this one in the photo is 1-1 the belt is a poly-v belt
#10
| Hi alex 850 I used to build them 5 at a time, but the cost is very high, You can do this yourself, not the same but will work almost as good, I could walk you through it & it should not take very long to do. The head you see has a disc brake, there is many things that you can't see that were changed, that is why I say you can do it with what you have. This is a photo of the brake setup
__________________ Mactec54 Last edited by mactec54; 12-30-2009 at 09:38 PM. |
#11
Hello Mactec I would be most interested to here of your rebuild and any drawings you may have that you would like to share even at a resonable cost to do a 1-1 conversion as My machine sits very close to the ceiling of my workshop and it would help to loose a couple of inches off the height. Cheers Colin |
#12
| Hi colin1544 I would be glad to help anyone that wants to do a conversion, this can be simple or very complex, I would suggest the simple, which involves very little change to the machine to do this, The one in the photos I still have, This was the last one I did just over 10years ago, it still looks as the photos do & runs production 4/ 6 days a week, In your case were you want to take some out of the top, would take a little more than someone who just wants a straight 1-1, you would only have 4 parts to machine on the head plus the new pulleys if you make them
| JDs BP J-Head CNC Conversion Blog | jdelaney44 | Bridgeport and Hardinge Mills | 216 | 09-07-2008 06:01 PM |
| Newbie- Series 1 2J head CNC retrofit. | roady89 | Bridgeport and Hardinge Mills | 6 | 04-29-2008 08:16 AM |
| Head Removal On Series 2 Cnc | TPMX | Bridgeport and Hardinge Mills | 4 | 01-29-2007 04:54 PM |
| M head conversion? | teufel | Bridgeport and Hardinge Mills | 3 | 01-10-2006 07:44 PM |
| Full Head Z Conversion | IndHobby | Product Announcements & Manufacturer News | 0 | 03-12-2004 10:51 PM |
