Old 12-27-2009, 11:33 AM
Holzwurm56 is on a distinguished road
EZTRAK Software
Hello ,
I am using a BP EZTRAK 2 CNC 3 Axis with software Version 4.00 Sn.: 8656E from 2000 . The machine was building in1998 . Is there a newer software available ? Is it possible to run the programm on a normally computer to create cam files at home ? Does someone knows a easy to use CadCam Program what creates camfiles for the Eztrak 2 ?
Many thanks for every answer
Hans
Old 12-27-2009, 03:42 PM
colin1544 is on a distinguished road
EZ-Trak software
Hello yes there is a version of software that can be run on a PC at home the version I have seen is a earlier one with just 2 axis but has the ability to input a Z move. I am also waiting for a copy of version 23 Bobcad cam which according to the rep has a post proccesor for the EZ-Trak, so when it arrives I will let you know unless someone else can already advise us if they have tried it and it works. Cheers Colin
Old 01-07-2010, 03:28 PM
Eztrak software
Hello Hans did you get any further with any offline software, if not let me have a PM of your home address and I will send you a copy of this early software, it will need a computer with DOS loaded and running. Please let me know if this is any use to you Cheers Colin
My Email is colinwildgust158@btinternet.com
Need Help!- bridgeport EZtrak SX pedro.ledezma Bridgeport and Hardinge Mills 1 04-19-2008 11:07 PM
EZTRAK problems driveshaft Bridgeport and Hardinge Mills 11 01-23-2008 07:40 PM
EZTrak CRT md63825 Bridgeport and Hardinge Mills 1 01-23-2008 02:30 PM
EZTRAK DX II Zombiestomp Bridgeport and Hardinge Mills 2 01-05-2008 02:10 PM
Help for Eztrak 2 Holzwurm56 Bridgeport and Hardinge Mills 0 11-04-2007 08:55 AM
