Old 12-17-2009, 05:56 PM
novice5 is on a distinguished road
Having trouble with steppers on Boss 6
I am having trouble with stepper motors on a boss 6 series one Bridgeport. None of the axis will run as they are supposed to. Each seems to try to run I have removed one motor and took cover off of the y axis so I could see why the motors seem to run but don't. The motors will turn a small about in both dirictions but will not run as they should. If anyone knows of a posiable cause for this, please share it with me. Thanks
Old 12-18-2009, 08:47 AM
Moderator
machintek is on a distinguished road
These setters like everything perfect. Voltage and current.
If you have the maintenance manual these is a trouble shooting section where test points are shown and values given.
Typically there is issue with one axis, not 3. Thus I would be checking power at T2 the large transformer in the back cabinet up top. Check (from left) the first and 4th wire. What is the voltage? Then the 2nd and 5th, etc.
The most common issue with a drive is the final drive transistors. You should have a stack of them. 2N6547. Current should be set to 8 amps at the DC fuses. Note that never hook up or disconnect a meter or pull a fuse with the drives ON. Current is set by the ACC board.
George
Tags
bridgeport 1 boss 6, cnc stepper trouble., stepper trouble
Need Help!- BOSS I, DeskCNC, steppers don't work rpgdeity Bridgeport and Hardinge Mills 5 07-16-2009 03:38 PM
easy boss w/ fair wage or diffcult boss w/ high pay? Chipload Polls 17 06-11-2008 07:19 AM
still having boss 4 trouble jodybo Bridgeport and Hardinge Mills 6 03-05-2008 01:16 PM
Trouble with a series 1 boss 8 v2e3 fireman323 Bridgeport and Hardinge Mills 2 08-27-2007 06:53 PM
Bridgeport BOSS steppers with Gecko? damae Bridgeport and Hardinge Mills 10 10-09-2005 05:28 PM
