Results 1 to 5 of 5
Thread: Swarf in Coolant on Series I
    Sep 2007
    I just installed a flood coolant sytstem on my BP Series I CNC Mill. My problem is the swarf clogs the drains in the table. I can let the swarf run into the coolant tank, but I'm afraid of clogging my pump, even with a filter. Any ideas?
    Jul 2005
    England
    Has yours got the perforated steel covers over the drain holes on the table.
    Moderator
    Nov 2004
    Alternative: drain to a settling tank (where the chips will settle to the bottom, the coolant will use a spillway on the top to go into the pump tank).
    2nd alternative is to use a whole house water filter between the pump and the nozzle. None of the Bridgeport coolant systems were perfect.
    George
    Jan 2005
    Take a photo of your table were the drains are,on most there should be a perforated cover that has 2 screws that hold them in place. This stops the drain holes from blocking, & only the fine chips get through, catch the fine chips etc in the tank with a fine mesh strainer
    Mactec54
    Sep 2007
    The problem is the perforated covers on the table, they clog really fast. I may use a 2 tank system, a settling tank and a fluid reservoir. I'm surprised at the amount of swarf produced. Usually I cut dry and vacuum up the chips, but with the swarf clogging the drains I have to watch to make sure the coolant doesn't overflow. I don't think the Series I was meant to be run with a flood coolant system, but nothing like a little challenge!
    1. Table tray for coolant/swarf protection....
      By InspirationTool in forum Benchtop Machines
      Last Post: 02-12-2011, 10:35 AM
    2. Homebrew swarf air blower & coolant pump
      By guru_florida in forum Benchtop Machines
      Last Post: 05-28-2010, 02:20 PM
    3. Removing Swarf in Coolant
      By ranchak in forum General Metal Working Machines
      Last Post: 12-16-2009, 12:04 PM
    4. Using mist coolant with Hillbilly board (Series I BP)
      By Mr. Technical in forum Bridgeport and Hardinge Mills
      Last Post: 11-19-2007, 10:01 AM
    5. Coolant & Swarf problems on Homebrew CNC Systems
      By UKRobotics in forum General Metal Working Machines
      Last Post: 01-18-2005, 12:26 AM
