| Highly unlikely due to the way the nut has to be opened and closed along with the drive notches lined up. I had a kwik switch 200 mill until just the last couple weeks when I got a new mill that has NMTB 30 quick change. I have been wondering about ATC for this spindle but doubt it for the same reasons as the kwik switch. |
NMTB was *designed* for ATC. You do need to have some means of indexing the spindle to get the dogs lined up, but that's not really a big deal. |
Probably have to get rid of the erickson quick change nut on the bottom and use a power drawbar setup. Getting the dogs lined up might be tough with a regular ac motor, most of the toolchanger machines I seen had servo motor spindles that could accomplish that line-up easily. |
I am thinking a servo motor drive with encoder. That is how the commercial machines have their spindle drive. |
Have you ever priced out a 2hp servo? i could convert 3 of these machiens for the price of one spindle servo. |
| Shame you are not in the UK, I know a guy that has a toolchanger that is exactly the same as on that Shizuoka in the video and he is selling it. I was going to buy it for my Beaver NC5 mill but it would have needed too much in the way of alterations due to the unusually long pullstuds that the Beaver uses. The machine its on at the moment is a Machmaker and it just uses a power drawbar with normal screw threaded drawbar. The Dogs are removed on the spindle so no orientation is required. I was a bit sceptical that the removal of the dogs was a good idea but the machine is at least 25yrs old and a look in the spindle taper shows nothing has ever spun and the machine has had a hard life. Hood Edit, you will see pics of it in this thread, about halfway down the page. http://www.machsupport.com/forum/ind...,10331.40.html |
#10
| I have a kiwk switch spindle, so am familiar with it. Auto tool changing with that sping loaded nut would be a real feat. Other tapers would be much simpler with just a power drawbar. On my bridgeport, I have the option of simply removing the erickson quick change nut, I can then use standard nmtb30 holders and a drawbar, so it would make that part easier. |
#11
| Should be a fairly easy thing to do with an induction motor and a VFD. Have an air operated shot pin that locates in a hole/slot in a disc that is on the spindle. The control would tell the VFD to rotate at a slow speed and the shot pin released, as it came round to the hole/slot it would allow the pin to drop in and a limit switch on the pin would let the control know its in place and to stop the VFD. Once toolchange is complete the control would release the pin and the same limit would tell the control the pin was out and it was safe to proceed. Hood |
#12
| Hood |
| Need Help!- excello xlo 602 mill help! | xlojon | Knee Vertical Mills | 22 | 02-17-2011 09:13 AM |
| Need Help!- WTB Kwik Switch 200 Series Tool Holders | Shanghyd | Want To Buy...Need help! | 0 | 11-24-2009 08:06 PM |
| narex on a Kwik switch 200 ? | tom bryant | General Metalwork Discussion | 6 | 03-11-2007 10:30 PM |
| clattering kwik switch? | arsenix | Bridgeport and Hardinge Mills | 5 | 11-11-2005 10:03 PM |
| How do I remove a kwik chuck/spindle | Andyh | Bridgeport and Hardinge Mills | 1 | 08-14-2005 12:28 PM |
