Hello, I'm an EZ Trak owner and it may be helpful for owners to share general info. My BP has been running well since 1996, I have done some great projects on it. I've discovered some interesting things about the old "EZ Crash"! If you have any useful info, please share it here. To begin with, here is a nice tidbit: Recently I had to replace the bulb behind the green button on the motor control pendant. It is a #949 bulb, 130V, and McMaster-Carr has them, p/n 1505K422, $9.86 each. 949 bulbs are common enough, but Light Bulb Emporium also has a LED replacement version, which should last quite a bit longer: p/n 81190EK (www.lightbulbemporium.com). Also recently replaced and something that makes my Trak very happy is a new keypad. It is a direct replacement and fixed the aggravating "double-key" syndrome. Older EZ Traks had a slightly different key style, which might make it hard to re-use the colored keys, but somewhere around 1995 they went to this style. Go to MaxGeek or ErgoGeek (through Amazon) and get the Ione Scorpius-32 keyboard - p/n SC32 - $44.95 (Helps to Google it.) Monitors are another issue. If yours burns out, a flat-screen LCD will work, and it comes up in color. If you want a close fit, try a 9" VGA Monochrome monitor, I got one but don't want to tear into it until my original monitor goes bad. Possibly this one will work: http://www.provantage.com/miracle-bu...7~7MRCL00N.htm When I first searched for the monitor, EMI said they could do a better-than-original retrofit, but you have to send the pendant back and it's not cheap. Not sure if that still stands. http://www.emi-inc.net/ Links like that are very good to know about. Also see http://www.hardingerepair.com/ |
| I am in the process of rebuilding an Ez-Trak and appreciate you starting this thread. I do not have much to add yet but most likely will when I am done with my machine. Thanks for the keyboard info; I am going to order one tonight. Mine is sticky and down right ugly and I was afraid to price one from EMI or Hardinge. |
i have just started upgrading my ez trak because i have some spare time before x-mas. the mill has been down for almost a year now, and i replaced it with a Milltronics VKM 4 that had been repo'd in my part of the country. i am using parts from EMI for the rebuild, along with my own retrofitting. i needed a new motherboard from EMI along with new software and disc on module. i built my own enclosure to hold a 15" lcd monitor and full keyboard. this weekend it should be up and running. keith |
Hi everyone i have a eztrak sx but when i turn off this machine from the main power swicth on the back and i try to turn on again the machine does not start i have a diskette but the not start correct on the screen show floating error. somebody can help me to get a copy of the startup files i think my diskette is damage. thanks. |
Hello Yes it would be interesting to get more info from other users, I have a later version of the Ez-trak which is a Ez-plus 3 axis with the later upgrade of controls and the colour LCD screen but the menus are almost identical. It has proved to be a good reliable machine at the moment although I did have a problem after about 1 month in when the main isolator went down I picked up a replacement from Ebay which was fortunate as a replacement from Hardinge Bridgeport was about $2500.00, in the UK the version we have is slightly different in that there are a couple more manual switches which is all to do with health and safety and unfortunately the US version of software will not run on it due to the differances in the PLC. But I am looking for a copy of the offline program called EZ-SPS so if any other users have a copy I would be most grateful of a copy as it is not available in the UK, look forward to other user's info and comments. Cheers Colin |
| [QUOTE=super-cochikui;703026]Hi everyone i have a eztrak sx but when i turn off this machine from the main power swicth on the back and i try to turn on again the machine does not start i have a diskette but the not start correct on the screen show floating error. somebody can help me to get a copy of the startup files i think my diskette is damage.QUOTE] Oops, I just realized something - There is a big difference between the EZ Trak SX and DX - the DX has a hard drive, and the software disk I have is an install-to-HD disk. Sorry I don't have what you need for the SX. Maybe someone else could zip the thing up and send a copy. The machine should always be booted and operated with a copy, and the original kept safe somewhere. Someone is sure to have one? |
i have my mill up and running now, but have found a few problems in the software. i am using ver. 7 from EMI. is there a new manual that goes with this software? my machine was originally ver. 3.63 and had it's own list of bugs in the software. i still have to wire usb ports on control panel for file transfer and repair the power drawbar. thanks keith |
Cheers Colin |
#10
Is wiring up USB ports one of those things that if I have to ask "how do you do that?" I would not stand a chance of doing it myself? |
#11
Hello Again I have just been looking at the setup files for the Ez-trak and noticed that in the parameter settings there appears to be a setting for a fourth axis and wonder if anyone has ever added this feature or if it is at all possible to add it, or is it that the program that the machine uses is a basic program for a multitude of different machines using the same software control program. Look forward to your info Cheers Colin. |
#12
| sorry "leftcoastcnc" that has taken me so long to get back to you about usb ports. my mill is up and running but i haven't made the cable for the usb yet. my plan is to mount the usb female sockets thru my control panel. i robbed the socket from an old pc. on the back of the panel i mounted a serial thru connector. i need to finish a cable to connect the end of the usb to serial plug, then i can run a serial cable down to the rear cabinet and connect to the motherboard. i have the new motherboard from EMI and obtained the data sheet for the motherboard to find the correct 9 pin connector on the motherboard to connect my converted serial cable to. from talking to EMI, this should work. i'll find out in another week or so. thanks keith |
| And Yet.... Another newbie that needs EZ trak info. | StilaR8dr | Bridgeport and Hardinge Mills | 13 | 05-18-2009 09:14 PM |
| Bridgeport EZ-TRAK | geno | Bridgeport and Hardinge Mills | 15 | 01-11-2007 03:31 PM |
| Info sharing | SPEEDRE | CNCzone Club House | 2 | 12-23-2006 12:03 PM |
| Bridgeport EZ-TRAK DX-2 | zukes3140 | Bridgeport and Hardinge Mills | 1 | 06-20-2005 09:58 PM |
| Bridgeport EZ-Trak,to buy or not? | BKP3855 | General Metal Working Machines | 1 | 11-01-2004 08:45 PM |
