Results 1 to 2 of 2
Thread: Bridgeport Ez Trak up & running
    Nov 2008
    I purchased a Ez Trak (1998-2000 vintage) for $1,660 this spring and finally purchased a rotary phase converter to power it. It's set up in the back corner of my garage. l wired in in last weekend and the monitor was blank although the light on the switch for the monitor was illuminated. I was having doubts that the thing was giong to work. I inspected the terminal connections in the electrical cabinet and found a disconnected wire this weekend. I now have a working CNC bridgeport mill complete with installation an maintainence manuals. Next step will be to purchase an R8 collet set. The mill also has a power drawbar installed. My only concern at this point is that the stepdown transformer is delivering 126v and the machine spec says it should be 115 +/- 5v. Is this really a concern, an electrician at the plant where I work indicated that it would not be a problem?
    Best Regards,
    Steve
    Moderator
    Nov 2004
    i would be more concerned with the axis drive power supply. So far though you are doing very well and the price cannot be beat!
    George
  1. Bridgeport EZ Trak-DX (1995)
    By rlmomc in forum Bridgeport and Hardinge Mills
    Last Post: 03-26-2009, 08:25 PM
  2. Bridgeport Trak CNC2
    By n174k in forum Bridgeport and Hardinge Mills
    Last Post: 12-27-2007, 02:56 PM
  3. Bridgeport EZ-TRAK
    By geno in forum Bridgeport and Hardinge Mills
    Last Post: 01-11-2007, 04:31 PM
  4. Bridgeport EZ-TRAK DX-2
    By zukes3140 in forum Bridgeport and Hardinge Mills
    Last Post: 06-20-2005, 10:58 PM
  5. Bridgeport EZ-Trak,to buy or not?
    By BKP3855 in forum General Metal Working Machines
    Last Post: 11-01-2004, 09:45 PM
