Old 11-26-2009, 10:26 PM
Bilkas is on a distinguished road
Thumbs down Single Phase Motor for Bridgeport Milling Machine
I am planning to buy a used Bridgeport (Series I - ???) milling machine for hobby use and would like to replace the standard 3 phase motor with a compatible single phase motor. I thought this would have been a rather straightforward matter; however, I have not been able to identify an appropriate replacement motor. The nameplate on a machine I was looking at stated the motor was a "56.5 Frame" but the existing motor looks like some sort of "C-Face" motor. I have replaced motors on other machine tools (with NEMA 56 Frame TEFC motors) and understand the NEMA naming convention for motor frames. Unfortunately, I can't locate any information about a "56.5 Frame." (I prefer not to use a phase converter because of the loss of efficiency and power.) I know I'm not the first person who has thought to do this and was wondering if anyone has successfully done so. Thank you!
Old 11-26-2009, 11:28 PM
HimyKabibble is on a distinguished road
You would be much better off buying a VFD. It's cheaper than a phase converter, and will also give you variable speed.
Old 11-27-2009, 06:13 AM
colin1544 is on a distinguished road
single phase bridgeport
Hello check the existing motor plate you may find it is dual voltage already and just needs the wires changing in the terminal box to set it for 240 volt three phase and just connect up a VFD it will more than likely be cheaper for a VFD than a single phase motor. Cheers Colin
Old 11-27-2009, 06:37 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
If it is 240 3ph, I would go with the converter type VFD
www.integratedmechanical.ca
110v single phase bridgeport motor swap stanglou General Metal Working Machines 22 10-13-2011 06:41 PM
fitting a 110v or 220v single phase spindle motor on a 3 phase machine mwood3 Benchtop Machines 12 10-12-2009 09:53 PM
VFD for a single Phase motor!! Yepez Servo Motors and Drives 4 08-10-2009 06:53 PM
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
VFD & 3 Phase Motor for Milling Machine. Willyb Benchtop Machines 29 03-14-2006 10:01 AM
