Old 11-25-2009, 11:01 PM
valmet58 is on a distinguished road
Thumbs down bridgeport series1 cnc
Hi Guys....do you know which cam program can generate codes which are
compatible with that machine (boss4)..
I tried deskcnc trial..it works ok BUT has a problem with the arcs..
before converting the cad drawing to gcodes I must make sure that an arc
most notcross a quadrant..what i mean is; let say an arc spans 180 degrees..
in my drawing i must draw two 90 degrees arcs..
It finishes by beeing a pain in the but.. Thanks
Andy
Old 11-28-2009, 03:52 AM
Neal.R2E3 is on a distinguished road
Look at onecnc they have a free dnc program called nclink register on their site and it's free http://www.onecnc.net/general/dnc_request.htm hope this helps.
Old 11-28-2009, 11:14 PM
Kevin Taylor is on a distinguished road
Boss 4
I would have to look in my manual but you might need to give a G75G90 comand to do a multiqudrant arc Bob cad has a post for all the old Boss machines also and you can change the setup to post in multi or single Qud. Good luck Kevin
Help w/Bridgeport series1 textron CNC MrHorsepower Bridgeport and Hardinge Mills 28 02-10-2010 01:49 AM
Need Help!- bridgeport cnc series1 boss4 Help valmet58 Bridgeport and Hardinge Mills 1 02-19-2009 10:13 PM
Need Help!- TNC145 SERIES1 BRIDGEPORT PierrePrototype Bridgeport and Hardinge Mills 5 10-26-2008 08:50 AM
Newbie- bridgeport series1 cnc Boss4 valmet58 Bridgeport and Hardinge Mills 3 09-07-2008 10:40 PM
What VDU for Bridgeport Interact Series1 ? awemawson Bridgeport and Hardinge Mills 5 03-10-2007 01:18 PM
