Old 11-24-2009, 11:15 PM
Shanghyd is on a distinguished road
Cutting an arc
I have a question on cutting an arc. I am using a Trak A.G.E. CNC Mill.
I know its not a bridgeport mill but there is no Trak section.
Here are my prompts:
XBegin
Y Begin
Z Rapid
Z Begin
X End
Y End
Z End
X Center
Y Center
Z Center
Conrad
Direction
Tool Offset
Z Feedrate
Tool #
I am trying to cut a rectangle that is 2.5"L X 3.5"W
There is a radius of .38 at the corners of the 2.5" length.
See image.
The way I want to cut it is to move to X0, Y0.
Move to Z0.
Move to X 2.5
Move to Y 3.5
Move to X0
I'm using a .5 endmill.
I don't know what value to put in the following to get the radius to come out right.
X End
Y End
Z End
X Center
Y Center
Z Center
Conrad
Direction
Tool Offset
Any help is surely appreciated.
Old 11-26-2009, 02:31 PM
Well I figured it out.
The conrad is set to .380 in the first event. .380 in the second event and 0 in the 3rd event.
Worked great.
oxy gasoline cutting torch - oPetrol cutting torch denniswang Product Announcements & Manufacturer News 6 02-20-2010 04:23 PM
Newbie- Newbie needs help! cutting acrylic, and double cutting? 3040 machine stephaniehamer Laser Engraving & Cutting Machines 5 06-29-2009 03:37 PM
Can Watr jet cutting and laser cutting make endmills obsolete? slashmaster Benchtop Machines 24 06-18-2009 04:07 PM
I need help about cutting heads which apply to apparel pattern cutting machine sheepgrass Mechanical Calculations/Engineering Design 0 05-12-2006 01:09 PM
