Hello to everybody. I own a Bridgeport VMC 800 digital since 1999. This model has the classic box ways in all axis. I have a problem with the central lubrication system since the machine was new, which was never solved because of the local dealership inefficiency which now doesn't exist. When the lubrication pump starts working the machine table shifts for almost 0.1mm. This causes me problems especially when I am copy milling with a ball end mill (i am a moldmaker). When the pump starts the table shifts gauging the surface that i am machining for as long as the pump operates. As a result the polishing of the machined surface takes much longer. Please advise. Thank you in advance. Dimitris |
| Never seen/heard of such a problem. Possibly a loose gib or keeper plate (excess play-worn out) on which ever axis is giving you the problem? George
| Similar to the concept of a bag with a little air pressure lifting a truck, if you have enough square inches. The way oil pump can put out enough pressure to lift a table or saddle. Usually these are made too tight, not too loose. George
| Need Help!- Need help with parameter setup and lubrication problem | Retief | Controller Cards | 0 | 10-09-2009 01:36 AM |
| Lubrication problem | Delw | Fadal | 6 | 09-14-2009 07:04 AM |
| Need Help!- Bridgeport EZ Plus error problem. | mscales | Bridgeport and Hardinge Mills | 6 | 04-07-2009 05:09 PM |
| Problem- Boss 8 Bridgeport problem | snovak240 | Bridgeport and Hardinge Mills | 6 | 10-22-2008 09:47 PM |
| Mazak FJV 250UHS lubrication problem | sting_dot | Mazak, Mitsubishi, Mazatrol | 2 | 05-21-2007 10:02 PM |
