Old 11-11-2009, 12:58 PM
2_many_hobbies is on a distinguished road
Bridgeport 2J Head
I am looking for re-assembly pictures of the bridgeport 2J type head, their is alot of pieces in the speed adjusting mechanism I don't understand.
This is what I found sofar but its too rough to really make since of it.
Old 11-12-2009, 11:31 PM
crabbass is on a distinguished road
what don't you understand? The handwheel turns a worm that drives a worm gear(2j547) for speed adjustment. This wraps a chain(2j572) around a pulley (2j514) that will pull down the clutch arm (2j507). When the arm is pulled down against the clutch the two sheaves (2j533)(2j534)force the belt out to a larger diameter, which in turn increases the pitch diameter on the driven clutch and decreases the pitch diameter of the drive clutch(2j668).
Old 11-13-2009, 03:26 PM
I got the lever action that when you crank the speed adjuster the lever is pulled down pushing the two drive cones together. What im stuck on is in order to transfer the belt motion to the spindle these must be press fit or in some sort of splined shaft (like a quill) so that you can move the top cone up/down but still transfer energy.
From the picture it looks like the lever is bearing supported on the top cone but I don't see the cone moving
Old 11-13-2009, 10:54 PM
the two sheave halves transmit their power through the straight sided spline that moves with the quill. the upper sheave half slides on a bushing (up and down)and is keyed to the lower half (so the two sheave halves rotate at the same speed). the lever arm pushes down on a collar with a bearing(similar to an automotive throwout bearing in a manual transmision)
Moving Bridgeport J-head Tailgunner Want To Buy...Need help! 0 06-15-2009 12:57 PM
bridgeport mill head serviceman Bridgeport and Hardinge Mills 0 05-13-2008 07:46 PM
Bridgeport J head - Do I need this???? bill south Bridgeport and Hardinge Mills 1 01-29-2007 03:28 PM
Bridgeport series I head ?'s toolndie7 Bridgeport and Hardinge Mills 1 12-30-2006 10:27 AM
M-Head Bridgeport for $650 - E-bay mxtras Bridgeport and Hardinge Mills 2 09-13-2005 09:39 AM
