I have a centroid control on my Brigeport boss 5. I cant get the Bijur lube pump to work. It has four wires coming out of the pump. 2 blue - out of the top and 2 red - out of the tank. any ideas???? Thanks for the help.. |
| probably can fax you the right documents. Jon |
| It sounds like a 1 phase pump. If so two are for the motor and the other usually a level switch. The 1 phase type often use a simple clock type motor and gear train. You may get a replacement from Bijur, otherwise there are other sources, I went through this a few years back. Make sure there is at least power on the two at the top, generally 120vac. Al.
| Need Help!- re Spindle Lube and Lube Pump | robkuhi | Tree | 15 | 10-24-2011 12:49 PM |
| Need Help!- Don't know where to put this. Lube pump wiring | RP Designs | General Electronics Discussion | 5 | 09-05-2009 06:56 PM |
| Bijur Pump - Wiring? | Scott Kelley | General Metal Working Machines | 1 | 09-22-2008 01:37 AM |
| Looking for info or manuals for old bijur lube... on BP series 1 | peter.blais | Bridgeport and Hardinge Mills | 18 | 10-17-2006 04:05 PM |
| BOSS 5 Bijur oil pump help | braidmeister | Bridgeport and Hardinge Mills | 8 | 05-31-2006 12:01 PM |
