Old 11-04-2009, 05:28 PM
Mike Woo is on a distinguished road
TNC145 ovals?
Hi.
Can anyone tell me if it is possible to machine an oval, outside dimensions 125.4mm x 94mm on a heidenhain TNC145c? Cheers.
Old 11-04-2009, 09:26 PM
Superman's Avatar
Superman is on a distinguished road
Can you scale inividual axes ?
program a 94mm circle
scale the X axis up by 1.33404 (125.4/94 ), leave the others as 1.0
PS---program the circle seperately, and around X0Y0 to make it easier
Old 11-05-2009, 03:27 AM
Oooh thats cunning! I see what you are doing there.
Er... i dont know. I will have a look at the parameter list and see if i can do anything in there.
Thank you.
Old 11-05-2009, 05:21 PM
Cant find anything in the parameters that i can adjust. Any other ideas? I have a feeling it could be done with "rnd" function but i am not sure.
Cheers
Old 11-05-2009, 09:40 PM
Superman's Avatar
Pity, would have been easy if you could
CAD-CAM avialable ?
If it is, you could do a circle and scale the X-axis to get an oval and then apply a toolpath to machine it
Cost to cut ovals in full sheets of plywood kengo General Business Practices and Pricing 2 07-02-2008 08:25 PM
Help!! Using Formulae to turn ovals with Mach3 rajiv.tctech General CNC (Mill and Lathe) Control Software (NC) 2 03-11-2008 10:23 PM
Problem- interact tnc145 bigbaz Bridgeport and Hardinge Mills 6 02-02-2008 10:19 AM
Ovals! cxixer Autodesk Software (Autocad, Inventor etc) 2 01-31-2008 06:32 PM
Kcam not seeing ovals properly monkamarm2000 General CNC (Mill and Lathe) Control Software (NC) 9 06-30-2005 02:40 PM
