Old 11-02-2009, 12:17 PM
Gsparkey is on a distinguished road
All drives not working
Hello,
I'm new here to the site & want to thank all of those who assist those of us who need the help. I have a Bridgeport Boss 5 machine, in fact I have 2. The 1 machine I have has had a serial port RS-232 cable connected to the 3 wires of the K-6 plug on the ESR board for the transfer of programs to the machine. Everything with this machine works fine. The second machine is again a Bridgeport Boss 5 machine. I have installed this same serial port cable set up to it & have had different problems getting the computer to recognize the machine to transfer a program. After numerous issues like changing out ESR boards, RCK boards & then finally changing out the bolt on board for the Z drive that goes on the inside of the back door of the logic control cabinet. Once this was done I could finally transfer data. And ran the machine for a few hours. The machine was shut off for 2 days & when powered back up. The operator's main control panel would reset n read no error codes but could not be cleared to do MDI input to drives or anything.. We have since changed out the ACC board & that has given me back the Y axis drive & a skipping X drive. The Z drive can be heard like its running but no movement. Can some1 give me an idea of where I should start looking to solve this problem. Any help would be greatly appreciated.
Thanks in advance..
Gsparkey
Old 11-02-2009, 07:16 PM
Moderator
machintek is on a distinguished road
Do you have the maintenance manual?
I believe you may have shorted transistors in the final drive section. 2N6547.
But I would also check the DC current and make sure it does not exceed 8 amps and that the output of T2 does not go higher than 63VAC.
Start there.
George
Old 11-03-2009, 07:07 AM
George, thanks, I have read some other post on here where you have told people the same thing & will be checking the voltage & amps on T2 & also adjusting the voltage to the drives using the pots on the ACC board to read 7.95 volts.. As far as the Maintance manual goes I only have a programing manual & an operator's manual, i have both on cd. If you know of any place i can get a manitenace manual I would appreciate it. Thanks Again I will keep you poted what I find out..
Greg Spangler
Old 11-03-2009, 07:20 AM
Moderator
Maintenance manual available on CDROM from machinemanuals.net for a reasonable sum.
ACC sets the CURRENT which is measured in amps.
There may be other items to check but check these first.
George
Old 11-03-2009, 08:31 AM
Thanks again George. I will make sure the multimeter is set appropately. While i have your attention, could you tell me where I could get these transistors if I need some.
Greg Spangler
Old 11-03-2009, 10:00 PM
Moderator
Any electrical supply house such as DIGIKEY, or even Ebay.
George
Newbie- Don't know what I need to get this working, need help! leirpytt General Electronics Discussion 6 04-13-2008 02:41 PM
Eia Iso Not Working honk Mazak, Mitsubishi, Mazatrol 12 08-16-2006 07:17 AM
Can someone help me with these motor/drives, I think the drives are dodgy? Darc Stepper Motors and Drives 1 07-23-2005 06:31 PM
What I'm working on- CNCadmin Forum Questions or Problems 2 07-21-2004 11:31 PM
Something I was working on when 22 Hobbiest CNCzone Club House 1 03-13-2004 07:27 AM
