Old 11-01-2009, 06:16 AM
nippy7 is on a distinguished road
EZ-Trak SX Software
Hi, Firstly i aplogise if this has been posted before. I did search but couldnt find anything.
I am running an EZTrack SX. The only date i can find is in the manual, it says March '94
When i purchased the machine it never came with any software or drivers apart from the one for the monitor. What i wanted to know, is there anywhere that i can get the software/drivers? Be it for download or purchase.
Many Thanks
Old 11-01-2009, 10:10 AM
mmckell is on a distinguished road
i was nosing around on the net looking for info for my EZ Path S and found this
hope it helps
http://www.emi-inc.net/BridgeportQuickList.html
Mac
Old 11-01-2009, 10:46 AM
Moderator
machintek is on a distinguished road
As I have posted before, I would not go above VER 3.02 for a SX EZTRAK.
EMI does sell software but they may require a upgrade of the motherboard, including the use of a DOM (disk on a module).
The original SX boots from a floppy as there was no hard drive. Most made a copy of that disk and put it in a safe as floppys in a machine shop environment have a high failure rate.
There is only one file that is machine specific, the SYS.BEZ file. It has machine travels, backlash, and the last place zero was set in the file. Later versions added pitch error compensation to the file.
George
Old 11-03-2009, 07:02 AM
colin1544 is on a distinguished road
Eztrak SX software
Hello Nippy I can probably help you out with a copy of software but it is from a DX machine which is probably later than yours. Have you tried Bridgeport Hardinge at Leicester they are most helpful and if you give them the serial number of the machine they may have the parameter settings for it on file, although I don't know how far they go back with records. If I can be of help please ring on 01159389014 Nottingham area so not to far away Cheers Colin
Old 12-21-2009, 03:32 PM
lgrijalva is on a distinguished road
Hello, i had i problem, i have an eztrak dx two axis machine, it comes without the system or installer diskettes but the machine was working ok, but I just los the hard drive where all the stuffs where, so, is there any chance that i can get this installation software from you?
Just in case that you can do that my email is lgrijalva@diferro.com
Kindly Regards.
Luis Grijalva
Need Help!- EZ-Trak DX2 ver3.8 software Sky-high-11 Bridgeport and Hardinge Mills 3 04-23-2009 12:54 AM
EZ Trak Software version opinions please ivangene Bridgeport and Hardinge Mills 2 04-20-2009 05:10 PM
Need software for EZ-TRAK PLUS fourthgenss Bridgeport and Hardinge Mills 0 07-28-2008 03:51 PM
BP series 1 Trak CNC2 software? BDMS Bridgeport and Hardinge Mills 14 04-27-2007 12:54 AM
Searching Update EZ Trak Software Holzwurm56 Bridgeport and Hardinge Mills 4 04-29-2006 10:54 PM
