Old 10-29-2009, 09:39 PM
JHCHOPPERS's Avatar
JHCHOPPERS is on a distinguished road
BP Interact 412 Y Axis Thrust Bearing
Does anyone know a source for a BP Interact 412 Y Axis Thrust Bearing? Doing a rebuild/retrofit and this one has about 0.006 play in it.
Thanks,
Joel
Old 10-29-2009, 10:02 PM
Moderator
machintek is on a distinguished road
Have you tried Hardinge?
George
Old 10-31-2009, 08:27 AM
JHCHOPPERS's Avatar
Yep, just got the cost back for the bearing only.... $720.00
So, we will be making a new assembly with an off the self bearing. I am thinking total cost ~$100.00
Old 10-31-2009, 10:10 AM
mactec54 is on a distinguished road
This guy might have them as well, BPT Parts 203 877 8054 Mike, He may be cheaper than Hardinge
Mactec54
Old 11-02-2009, 04:15 PM
JHCHOPPERS's Avatar
Thanks for your help ! I will call him.
Does anyone have a parts book for this machine ? I am looking for the part number too.
Thanks,
Joel
Old 11-02-2009, 09:23 PM
JHCHOPPERS's Avatar
Found the Part Number !
1720594 'ina' Bearing_zklf_2527_2rs
Old 11-06-2009, 08:58 AM
JHCHOPPERS's Avatar
Did some research over the last couple of days. There are cheap thrust bearings ( $20.00 - $40.00 range ) , good for General Purpose applications and there are High Precision ones ( $300.00 - $500.00 range ) for precision applications like Milling Machine Thrust Bearings.
So, the cost to build our own is now about $800.00! The good news is, there is a guy on eBay (seller name is partsman06460 ) and he has NEW replacement bearings for $555.00
Hope this helps someone else sometime.....
JH
X-Axis Thrust Bearing? TurtleRacing Fadal 13 05-21-2009 06:22 PM
MV Jr. Z Axis thrust bearing replacement TWyatt9 Mori lathes 0 11-26-2007 06:19 AM
Thrust bearing numbers geebee1912 Fadal 0 08-25-2007 12:43 PM
Mori Seiki Z axis Thrust Bearing TWyatt9 General Metal Working Machines 0 08-15-2007 09:25 AM
What do you think of this thrust bearing design? CNCadmin Benchtop Machines 0 06-03-2004 08:20 AM
