Old 10-29-2009, 04:53 PM
Kevin77 is on a distinguished road
Interact won't home axes
Hello,
My Interact S1Mk.2 was fine till yesterday. Upon powering up the machine, it runs the memory test, and then displays "power interupted." Hit CE, enable the drives, and then pressing Cycle Start should start the homing process, but nothing happens. I can hear a contacter in the spindle drive cabinet clunking when pushing the cycle start. 2 of the 4 LEDs on the servo drives are on. Anyone have any ideas?
Thanks,
Kevin
Old 10-29-2009, 10:11 PM
Moderator
machintek is on a distinguished road
Feedrate set to zero?
George
Old 10-30-2009, 08:48 AM
Hi George,
I checked that. This afternoon I will check that the pot is functioning and that the 12v supply is there. The 24v supply is ok. Could it be a fuse somewhere? I think the ones on the drives are ok as the LEDs are lit. Sure wish I could find a wiring diagram for this thing.
Thanks,
Kevin
Old 11-12-2009, 11:34 AM
To update: I checked the pots and the 12v supply for them, they are ok. I was able to get the cycle start circuit functioning. When I push cycle start, I get a humming noise from the filter choke associated with whichever drive is active. However, I get no DC out from the drives. They do have proper voltage going in. Turns out the transformers T1 and T2 were not properly tapped for my line voltage...had about 40 volts too much going to the Bosch servo drives. Is this enough to kill them? Also, the three drive enable relays are closing properly. My next moves include checking current draw of the drives, as well as checking the analogue speed and direction signals going in to them. Is it possible the extra voltage burned up the SCRs? Would they fail safe or shorted? Is there enough isolation between the power and control sides of the drives to limit damage to the SCRs and related components?
Any ideas? Also, keep in mind all three drives give the same symptoms. Is it possible/feasible that they all failed in similar fashion, or is there another control issue i'm missing?
Thanks,
Kevin
Old 11-13-2009, 05:31 AM
Jon18buc is on a distinguished road
Have you checked that mechanicalaly all ball screws move the axies easy.
if ok. check the analog input to drive cards before homing then check voltage while referencing with the feed pot full up. there should be a voltage present on the axis that is homing.
Old 11-13-2009, 09:13 AM
I checked the analogue output yesterday. There is none. The ball screws all move easily. Heidenhain tells me the machine is in a "feed hold" because the feedrate is highlighted on screen. They say some input somewhere is missing, and the control won't go because all external feedback is not being satisfied. The lube oil level is fine. Any other ideas?
Also, i checked current going into the drives, and read "0." Obviously they are not starting. Are the drives supposed to be active when the inhibit/enable relays are on or off?
Kevin
Old 11-14-2009, 09:28 AM
Check your lubrication level and then check the float switch is working electrically.
Old 11-14-2009, 09:38 AM
Moderator
On the BOSCH drives there are 4 green LED. Two are lit when drives are enabled, 4 are lit when drives are homed.
Drives are enabled by relays. Look at the schematic. I do not have one in front of me.
Check these first. What control model do you have? You may be able to access the outputs to verify the control is trying to turn the drives on.
George
Old 11-14-2009, 09:42 AM
acording to my electrical drawings the lube switch drives 2CR.
I belive it should be energised.
Old 11-14-2009, 05:18 PM
George,
Two leds come on all three drives when the main feed contactor (5FC) turns on, via the power enable button. The other two come on on whichever drive is being activated when I press the cycle start. They turn off when i press cycle stop. The three enable relays, 12,13, and 14CR are turning on and off in similar fashion. But no analog output.
Jon,
The oil is topped up and relay 2CR is turning on properly, so I don't think thats the issue. However i will check the switch electrically.
The control is a TNC 151B.
As always, I really appreciate your help!
Kevin
  #11   Ban this user!
Old 11-16-2009, 05:14 AM
Hi Kevin.
Think you will have to check the input voltages on the terminals at the rear of the Heidenhein. using a meter. Also check the regulated 24V is 24V and virtually ripple free.
Check the joystick feed back and make sure the rapid signal is working OK.
It will be possible to check all the signals at these terminals and one could disconnect reconnect or jumper the inputs for test purpose.
  #12   Ban this user!
Old 11-18-2009, 04:37 PM
Well I'm one step closer to getting it fixed. I was able to get the correct schematic and a list of the factory parameters from hardinge UK. For everyone else's reference, jwright@hardinge.co.uk was my contact.
Hopefully tomorrow I'll have time to take a look.
Kevin
Newbie- Part Home vs. Machine Home Mihelich G-Code Programing 6 06-07-2009 01:56 PM
Anyone doing 5 axes? Pukwudji DIY-CNC Router Table Machines 5 05-26-2009 04:01 PM
5-axes PP for CATIA mitak_t Post Processor Files 2 11-22-2007 08:04 PM
can't jog axes BobM3 Fanuc 2 10-23-2006 04:00 PM
4 Axes GOBUS DIY-CNC Router Table Machines 0 12-07-2005 07:29 AM
