Old 10-29-2009, 02:00 PM
Sandor_nl is on a distinguished road
need parameters for lubrication timing
hi
i have a bridgeport with a heidenhain 370
this thing uses more oil then my car
now it lubricates every 15 minutes and i am using about a litre a day..
we only use the machine for very light work and do a lot of programming.
can someone tell me wich parameter to program to set that timer to a lower value? (switch on timer)
thanks for the help
SHM0609 lubrication carveit Excitech routers 10 02-27-2010 05:33 AM
Lubrication problem Delw Fadal 6 09-14-2009 07:04 AM
Help determining latency and EMC timing parameters.... margni74 LinuxCNC (formerly EMC2) 4 12-05-2008 04:05 PM
Lubrication bohica Industrial Hobbies (Support forum) 17 04-29-2007 01:13 AM
Lubrication BeerFizz Benchtop Machines 5 11-09-2005 06:25 PM
