I just picked up a Bridgeport Series 2 CNC mill and like the title says, its too tall to get in the gargage. My garage clearance is 7ft. This mill is 7ft 4inches at the tallest point. There is a lip leading into the garage that the mill has to go over and the pipes to roll it on will be about 1 inch in diameter. My solution is to take the head off the machine. Not the whole J shaped head that fits onto the base, just the spindle motor and other parts of the head. So my question is how difficult is it going to be to take these parts off? The machine has servos. Is it possible to throw them out of wack or somehow misalign the encoders or can I just disonnect the wires and everything and there won't be a problem? Thanks for any advice and precautions. |
Regards, Ray L. |
| Looks like a series 1 to me. If you have access to a forklift you could do the same as I did, get the left fork just behind the head and attach to the ringbolts with a strap or rope then lift a bit. I then put a ratchet chain hoist from the other fork down to under the back of the base and tilted it , lowered it back down when at an angle so it was just clear of the ground, drove in, raised and then put it back vertical by loosening the hoist then lowered to the ground. Took about 10mins myself but if you dont have a forklift then thats not going to work and you will probably have to unbolt the head as you said and undo all the wiring to the motor and switches, there are also lube pipes to the ballscrew etc so make sure you undo them as well. Hood Oh BTW it would be the opposite way for the forks if the mill was facing the way of that pic, mine was the other way LOL |
That's an excellent idea. I think that's the direction I'm going to pursue. |
| Karl |
#11
| Ideas not mentioned: Take the garage door down. Cut 6" slot into the garage door header with a chain saw. Move the machine in. Repair header. Reinstall garage door. Or bust up the concrete floor. Dig a trench. Pull the machine in. Fill the trench in with new concrete. |
#12
| Attached is a picture of the series 2 head that my machine has. This is not my machine. As you can see the head doesn't rotate. IF the part inside the red rectangle was disassembled then that part would come off and it would fit. However the front part where the quill and spindle are seems rather complicated. Has anyone ever taken this part off on this type of machine? I'm still working the bracket idea. I'm a little concerned about the stability of the head once I disconnect it from the ram and try to move the machine. I don't have a forklift or tow truck. All I have are engine hoists and pipes to roll it on. Last edited by Shanghyd; 10-30-2009 at 05:58 PM. Reason: typo |
| Series 2 cnc 2 hp motor on a series 1 bridgeport? | CATCH22 | Bridgeport and Hardinge Mills | 1 | 11-08-2008 08:18 AM |
| Small/Garage shops and the old Bridgeport. | katiebo | General Metal Working Machines | 8 | 03-13-2008 08:56 AM |
| Impact of Bridgeport in garage on Home Insurance? | damae | Safety Zone | 15 | 11-25-2007 02:41 AM |
| Tall vmc - Low doorway | rlevin | General Metal Working Machines | 8 | 08-30-2006 06:16 PM |
| How tall is too tall ? | samualt | DIY-CNC Router Table Machines | 3 | 07-28-2004 11:53 AM |
