Hi, I've got a VMC 500 in the shop. It doesn't do much, basically an accurate drill..... I'm having problems with the toolchanger. It was working when we got it (2yrs ago) but now it doesn't want to play. It goes to the toolchange position and either spins continously, resulting in an error message about orientation or gets past that and the carousel pops out and refuses to do anything else. I suspect the encoder might be knackered. Also, does this machine continuously use air? Obviously it needs the air for the toolchange, but should it continually use air? Or have I got a solenoid thats stuck open? Cheers Yarpo |
| What kind of drives and control? Probably Fanuc drives. Two types of orient devices used. One was a encoder, and the other magnetic. Spindle probably has a piggy back orient board with adjustments on it. Make sure orient LED lights up. (check your manuals for how to adjust) Then the carousel should come forward. If it stops there, either the control does not see the verification switch that it is forward, or it sees it is forward, but the drawbar cylinder did not fire or in the process of getting on the tool it rotated the spindle out of orient. George
| Dear All we have Bridgeport VMC-500/16Dig with Heidenhain TNC-415 controller, we are facing a problem in spindle running. it is working properly but after sometimes it gives an Alarn "8BA0 Incorrect Line Count S" & m/c is off. after switch Off & then Onm/c wil work properly. Pl. help me What is the problem & how it will Remove? |
| Dear All we have Bridgeport VMC-500/16Dig with Heidenhain TNC-410ma controller, we are facing a problem in spindle running. it is not working in M03 & M04 command & also not in manual mod.after getting M03 or M04 command it will not execute the command or not given any message. Pl. help me What is the problem & how it will Remove? |
| Build Thread- Bridgeport BTC-1 | METALTEK | Bridgeport and Hardinge Mills | 13 | 05-26-2009 11:32 AM |
| Bridgeport TC3 | HRL | General Metalwork Discussion | 0 | 04-11-2009 04:29 PM |
| Need Help!- bridgeport with 151 | bbrreid | Bridgeport and Hardinge Mills | 2 | 11-03-2008 04:35 AM |
| Need Help!- Bridgeport Help | bperfetti | Bridgeport and Hardinge Mills | 3 | 10-27-2008 08:55 AM |
| Bridgeport Needs Air? | JQ_Quint | Bridgeport and Hardinge Mills | 4 | 10-25-2008 03:46 AM |
