Old 10-13-2009, 02:02 PM
CT6277 is on a distinguished road
General questions -help
Newbie here from steel fab shop
Looks like we have 2 Bridgeport Boss series rigid ram mills
We use a old win95 pc with Tera Term program/terminal emulator to send txt files for drilling parts etc. via 9 pin-serial/com port
1. wheres the s/n located, I looked on the knee like some sites said and all I found was "CNC2230"
2. wheres a good source for manuals?
3.can these old mills electronics/hardware be updated to run newer software?
4. current problem: when I send a txt file to drill four holes it only drills 3 and quits. when I tell the mill to list the file it seems to receives it fine.
this all happened after both my 25 pin (Motherboard) com ports burned out and I had to install a PCI com port card. the new PCI com port card is a 9 pin and I converted it with a qvs brand "XT Mouse to AT" 9 pin/25pin adaptor.
Any ideas?
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 04:42 PM
Mazak qt-15 EIA and general questions lapoltba Mazak, Mitsubishi, Mazatrol 8 06-04-2009 07:10 PM
cnc general questions helodude1 Bridgeport and Hardinge Mills 3 05-12-2009 12:20 AM
A few general newbie questions sigipa General Metalwork Discussion 4 08-21-2007 04:41 PM
General CNC questions dmparrott DIY-CNC Router Table Machines 1 01-24-2007 09:16 PM
