Old 10-03-2009, 01:57 PM
mally is on a distinguished road
Heidenhain format for text files
Hi does anyone have a copy of the Heidenhain TNC 145 operation manual Code No1-104-0377 page 80 section j6 on proper Heidenhain format for the transfering of text files as I am having trouble with transfering a program from mac tnc145
Old 10-03-2009, 05:32 PM
gridley51 is on a distinguished road
I would normally refer you to the Heidenhain website but it`s been down for over a week.
If you call or email your nearest Heidenhain office,tech support will email you the manual and also give you direct help.
I have the 145 installation manual which touches on the format in chapter five if you want it in the meantime.
Mark.
Old 10-05-2009, 02:51 PM
gus gus is offline
gus is on a distinguished road
re
attached is a program, note the exact spacing between characters, the first line, numbers required, Cr, LF after each line
watch your ascii transfer style, that will frequently mess you up. Transfer a program out of the control then back in to check it.
Old 10-06-2009, 02:17 AM
The Plot Thickens
Great thanks for the info, it looks more like the old EZ-CAM/EZ-MILL comms and post I am using is set up to send in the right format, but it looks more likely that it is the TNC145 side which is at fault, Is thier any way of testing the V.24/RS232 port on the TNC145 for the correct volts/signals as the prog is NOT SENT and no error msg comes up on the tnc screen just the "ready for input" and only when you dissconnect cable does it change to "Not Ready" I have checked the cable and all seems correct.
Old 10-06-2009, 07:06 AM
gus gus is offline
I suspect either the cable or transfer setup
will the control output a program?
Old 10-06-2009, 12:19 PM
No not been able to pull prog back from 145 into cam, link cable has been checked and is correct to cam wiring spec and also baud rate is as spec 2400just seems to point to control port if only it could be checked out somehow.
Old 02-15-2010, 07:07 PM
hmc710 is on a distinguished road
Also Trying
Hi Guys,
I am also trying to upload a program into my TNC145. I finally got a program out, 953 lines, and, as Gus suggested, back in. It worked. Now I am trying to upload a simple program from Bobcad V21 and getting some different errors on the TNC. On the one where I get the first 6 lines of code, it comes up Wrong Data after 6 lines. The 7th line is an L command. I have tried different spacings, but no luck.
Stupid question time: My manual says CR is ascii 013 and LF is ascii 010 and I have to have them after each line. End of program is EXT, ascii 003. Is the Enter key the same as CR? I got no results until I deleted the first line of the program and hit the enter key, then it would upload to line 7 where I have a L (line) command and the TNC says wrong data. I'm so close, but still missing something simple. Any ideas?
Thanks!
Old 02-15-2010, 07:43 PM
still trying
Just did a save as *.txt file on my program file and opened it up and there are 2 spaces between lines. CR LF ? Tried to upload that and TNC didn't like it. Took out the 2 spaces and uploaded to line 7 where I have an L command.
First 6 lines are tool change and peck cycle
Old 02-15-2010, 08:17 PM
spacing is everything
program line spacing is critical as Gus stated above. Took me a while to take it all in. Program at machine and send to pc back and forth and starting to figure it out. Glad I did a search on this!
Old 02-16-2010, 12:04 AM
gus gus is offline
if you look at the program in an old version of notepad, it will show you the little symbols for lf and cr.
you may see some odd character in there
try deleting line 7, the 145 doesn't need sequential lines to upload. you can program line 768 all by itself and it will upload it. add in the line 7 in the machine, and then send it back to the computer to save it
you may find there are quirks like this, but once it is in the machine, and out again it shoould be fine.
  #11   Ban this user!
Old 02-16-2010, 06:29 AM
Spaced out
Thanks Gus, will try the notepad thing and see what shows up. My line 7 error was due to spacing and missing characters: 3 spaces to Xxxxxx 5 spaces to Yxxxx 23 spaces to Rx 1 space to Fxxx 2 spaces to Mxx.
I was also missing the 0 in the RO command. I will send Bobcad a note and the sample program to see if they can tweak their post processor. Still a whole lot faster tweaking a .txt file than doing a full dwg and entering all coordinates by hand. Kinda like when I had my first Microkinetics plasma cutter with .plt files
Thanks for the help!
Need Help!- Problems exporting Corel text files as DXF CustomConcepts Printing, Scanners, Vinyl cutting and Plotters 3 10-21-2008 02:24 PM
Converting Illustrator files to Gcode files acoop101 General Metal Working Machines 1 06-05-2008 04:53 PM
Heidenhain ManualPlus 4110 - GTI and GTZ files - cycles and outlines grzeniua General CNC (Mill and Lathe) Control Software (NC) 0 09-10-2007 05:48 AM
