Old 09-24-2009, 06:32 PM
gridley51 is on a distinguished road
Interact info needed
Which models of Interact (if any) were built with a Heidenhain 150 control and a dc spindle motor?
Mark.
Old 09-27-2009, 03:37 PM
colin1544 is on a distinguished road
Interact with tnc 150
Hello Mark the machine you are refering to was a Series 1 interact MK2, it is the same base as the origonal interact and the old series 1 boss machines, but the head was totally different it had the a spindle powered by a 6 HP DC drive motor giving a total control from about 60 RPM to about 4000 RPM it also had the quill feed linked to a twin ballscrew which gave it greater torque and precision and apparently alot smoother and quiter than the origonal interacts. I would love one of these but good ones are few and far between, hope this helps cheers Colin
Old 09-28-2009, 04:04 PM
Thanks Colin.
I`ve since found out that the Interact 4 has a similar setup.
Reason for asking was that I was considering rewiring a Beaver V5 the same as an Interact.This would let me get rid of the external plc and interface board that the Beaver has between the m/c and the control and for which there seems to be very little info available.
Need Help!- Bridgeport Interact 412 CNC pump needed TalonGrip General Metal Working Machines 0 09-03-2008 06:53 PM
Bridgeport Interact 720 Info? M.G.Machinist General Metal Working Machines 1 04-18-2007 03:52 PM
Advice Needed Regarding Bridgeport Interact Axis Motors UKRobotics Bridgeport and Hardinge Mills 2 02-09-2006 05:45 PM
Info on EDM needed cjs83 CNC Plasma and Waterjet Machines 7 07-07-2004 07:38 AM
info needed turmite Machine Problems, Solutions , Wireless DNC, serial port 9 08-02-2003 02:28 AM
