  #13   Ban this user!
Old 11-05-2009, 09:52 AM
WESTERNTOOL is on a distinguished road
Hello Jaff,
Did you get your millpwr fixed? I would suggest contacting Chris Hanson on this site as he is a service engineer for accurite. He can also be reached a @ 800-344-2311. Off the cuff sounds like you have a noise issue on the communications to the AMI box. Make sure the machine has a good ground. Not just the incoming power neutral, but a ground rod sometimes is necessary. I've installed and retrofitted a few of these controls.
Good luck
John Vukonich
  #14   Ban this user!
Old 11-06-2009, 03:20 AM
Jaff is on a distinguished road
Hi John,
Yes all fixed now thank you. We replaced the 5v Voltage regulator on the AMI board and the resistor connected to it and all is well!!
Grah.
PS.... John B, There is an company in Bristol, Sorted Machine Tool Services Ltd [Sorted-uk.com], who may be able to help with the millpwr system as I believe they are the SW agents.
Acu-Rite MillPwr Problems Tazzer Bridgeport and Hardinge Mills 6 03-08-2011 04:25 PM
Acu-Right Millpwr Tazzer Post Processor Files 7 01-14-2009 02:24 PM
Acu-rite Millpwr CRAZYRICH CNCzone Club House 2 01-27-2007 02:13 PM
Acu-rite Millpwr bybon Bridgeport and Hardinge Mills 1 09-18-2006 08:51 PM
MillPwr ddwiers General CAM Discussion 1 12-31-2005 01:37 PM
