Old 09-23-2009, 10:29 AM
Bill N is on a distinguished road
ez-trak not reading x axis in one direction
Does anyone know what might be causing the x axis not to read in one direction on a ez-trak/sx . Swapped out JP3 and JP2(X and Y inputs to axs bob card) and the problem moved to the y axis. Also, getting a flashing red light on the BMDC board. This is happening in manual mode (power off)
Old 09-24-2009, 07:20 AM
JoBwan's Avatar
JoBwan is on a distinguished road
Bill,
I'm not a 100% sure, but this sounds like it may be an encoder problem. Could also be a bad cable. Google "Clarkson Machine" and talk to Steve. He is fairly cheap and can test the motor/encoder, if it's an "SEM" motor. He normally has encoders in stock. Based near Chicago Ill. Good Luck.
Just a good ol' boy, never meanin' no harm.
Joe
Old 09-24-2009, 09:06 AM
Thanks Joe- I'll give it a try
Bill N
Need Help!- EZ TRAK OFF IN Z AXIS dmac88 Bridgeport and Hardinge Mills 3 07-08-2009 01:22 PM
2 axis EZ Trak post? zcases Post Processor Files 3 12-18-2008 05:42 PM
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 04:33 PM
4th Axis for EZ Trak Grayling Bridgeport and Hardinge Mills 2 09-01-2008 02:05 PM
EZ-Trak Z Axis Trouble ivangene Bridgeport and Hardinge Mills 2 01-24-2008 01:40 PM
