Old 09-22-2009, 12:10 PM
mmri1 is on a distinguished road
Question Boss 5 stepper motor
I can not get the Z axis motor to run on my boss 5, took belt off motor is locked when on, switched smd,acc cards,transistor block, checked fuses & power supply. can motor be bad?
Old 09-22-2009, 05:21 PM
Moderator
machintek is on a distinguished road
That is normal for a stepping motor. When energized it is stationary but a firm hand can still turn it. As you turn it you can feel the poles of the motor.
When OFF, it turns a lot easier but you can still feel the poles of the motor. On a new motor the poles are stronger. On a old motor the poles are weaker. Thus a old motor cannot accelerate as well, the current does not drop as far at rapid (another way of knowing the health of the motor), and the motor will stall easier under load.
Read up on stepping motor theory.
Have you checked voltage and current?
George
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 05:56 PM
BOSS 6 stepper motor pestana1957 Bridgeport and Hardinge Mills 0 02-11-2007 06:01 PM
Wanted - BOSS 5 Stepper Motor (good or bad) Eric Bridgeport and Hardinge Mills 0 04-06-2006 10:14 AM
Boss 5 Stepper kewl_cat Bridgeport and Hardinge Mills 2 11-22-2005 08:56 PM
Boss 5 Stepper ? MrHorsepower Bridgeport and Hardinge Mills 2 08-03-2005 09:43 PM
