Old 09-14-2009, 04:11 PM
thomasmc is on a distinguished road
Lightbulb bridgeport interact 1 cant get power to come on
Hi my problem is on turnining the machine on,when i press the green power on button the machine trips out the mains.
Now when i turn the power on no nothing is lighting up at the screen.
I have checked all the fuses they are OK.
The machine has a tnc 145 control.(any thoughts)
Old 09-14-2009, 09:57 PM
Moderator
machintek is on a distinguished road
The TNC-145 has a fuse in the center of the voltage dial on the back of the control. Did you check that one?
Check power in, how all the transformers are configured, and hopefully you are using true 3 phase power.
George
Old 09-15-2009, 12:35 PM
thanks for your speedy replay i will check for that fuse in the morning
Interact 308 Bridgeport ?/:???? SGARCIAM Bridgeport and Hardinge Mills 0 08-21-2008 05:22 PM
CNC Bridgeport II interact 4 Tnc 150 frenk59 Bridgeport and Hardinge Mills 12 08-06-2008 08:49 AM
Bridgeport Interact 1 MK2 Leyland 472 Bridgeport and Hardinge Mills 3 10-20-2006 07:44 AM
Bridgeport Interact Series II Power Drawbar UKRobotics Bridgeport and Hardinge Mills 9 09-15-2006 08:27 PM
Bridgeport Series 2 Interact 2 Power hook up problem! Help! Huntersyv Bridgeport and Hardinge Mills 7 01-09-2006 02:57 AM
