I bought a "Series 2" R2E4 cnc machines at an auction a while back (along with a manual mill and engine lathe) and have finally gotten them up and near running. I'm not sure why they called this machine a series 2; it's more like a series 1.5- it still has the smallish 2hp head and base casting, but has box ways instead of dovetails. Anyways, I can't get the machine to power up, and I later heard from a machinist in the toolroom that it came out of that they had always had control/board problems with the machine. I'm not very knowledgable with the electronics side of the biz. Physically, the machine is in good shape; the ways are very clean, the table isn't damaged, the coolant pan is there, the mist/flood systems are intact, and the upper control panel is clean. But, if I can't get it to work for less than what I have into it, then it is no good to me. I was talking to a guy tonight that retrofitted an older Cincinnati bed mill to run G-Code off of a PC (and uses BobCad to program), but I can't remember the control system. He said it was relatively easy to set up and could probably be done for $1000-$1500 or so. If I can't find a reasonable solution, I'm going to try and sell it outright or sell it for parts. Can any of you point me in the right direction? I appreciate the help!! |
| What exactly is your question? The series 2 was meant to support more weight. If they put a bigger motor on it, the entire machine would need a redesign to keep rigidity, etc. Does the door have a fan on it? There were a lot of thermal issues with the BOSS 9 causing board failure. Bridgeport came out with a door exchange program to retrofit the control cabinets with a fan and filter to minimize this. Maybe the original owners never took advantage of this. Are you on true 3 phase power? Are all the transformers configures for the power going to the machine? Do you have the maintenance manual? Have to looked at chapter 7 and checked voltages (and fuses) with a meter? What does come up/work? I had a BOSS 9 and made a living with it 23 years ago. Good machine. George
| It came out of a Delphi toolroom auction about a year ago and from what I gather from a few toolmakers that I know in there, they have always had electronic problems with it and it wasn't working at time of sale. I know this now. It was wired for 440, now I have the control, transformer, and motor wired for low voltage 3 phase for my convertor. I have it wired into a 10hp rotary convertor. Powers my engine lathe and 5hp manual mill just fine, but those aren't cnc. I believe it does have the fan on the electrical cabinet. My machines aren't located at my house- that's where I am right now. I haven't messed with it in a few months; been concentrating on sorting out tooling for the other machines and working out little bugs with them. I don't remember being able to get the control to power on though. I got a fair deal on it, so if it's gonna cost me major dough to fix it; not worth it to me- I'll sell it for parts. Mechanically it's very sound. A friend of mine has performed more than a few retrofits of his own and suggests a possible conversion to mach3 / gecko or similar. Not sure I want to go thru all that. |
| Need Help!- Bridgeport Series 1 R2E4 | Tommy | Bridgeport and Hardinge Mills | 20 | 03-21-2010 06:49 AM |
| Looking for a BSP card for Bridgeport Series I R2E4 | synergymc | Controller Cards | 0 | 08-06-2007 10:36 AM |
| Bridgeport Series 1 CNC R2E4 (??) | l u k e | Bridgeport and Hardinge Mills | 4 | 01-25-2006 03:06 PM |
| Bridgeport Series 1 CNC R2E4 (??) | l u k e | General Metalwork Discussion | 8 | 01-24-2006 07:39 PM |
| Drawbar For Bridgeport Series I R2e4 | synergymc | Bridgeport and Hardinge Mills | 1 | 08-24-2005 07:22 PM |
