Results 1 to 4 of 4
Thread: V2XT running hot! Help!
    Mar 2007
    I’ve finally got my V2XT running again but when the spindle stops after finishing a program, the air blows out of the manifold at the rear of the machine. Do any of you know what the black boxes are with the red arrow pointing to it and why they are running so hot?
    Thanks in advance for helping out a newbee!
    Sep 2007
    ireland
    hi,
    not familiar with the machine but they look like solenoids on a hydraulic control block to me. basically they are coils of wire wound according to their voltage. anything from 12,24,110,240,380v. the 12 and 24 can be ac or dc. i have seen them run hot on some units as they can run all the time even if a machine is not processing. i wouldnt worry about it as they are designed to do this in some cases. also hot oil flowing nearby does not help with cooling. if they never were like this before pop off the caps and check the voltages with a meter and compare with the specs on the coil blocks.
    regards
    j
    Mar 2007
    Quote Originally Posted by camboy View Post
    hi,
    regards
    j
    Thank you so much for the comeback J! That is exactly what it is all right. I took the old unit off and took it with me to an industrial hardware supply and the new replacement was 56 dollars US. So we’re back to carving metal again and the spindle turns off without the air blast plus, it no longer runs hot.
    Sep 2007
    ireland
    hi,
    ok, i looked at it again and i see the hoses are air not oil.whoops. but the rest still applies anyway. glad you are up and running.
    regards
    j
  1. Problem- Bridgeport v2xt
    By Hogface in forum Bridgeport and Hardinge Mills
    Last Post: 03-11-2009, 10:19 PM
  2. v2xt post
    By jrrhotrod in forum Post Processors for MC
    Last Post: 12-10-2008, 06:20 PM
  3. V2XT Programming
    By NC Cams in forum Bridgeport and Hardinge Mills
    Last Post: 11-01-2008, 05:05 AM
  4. V2XT with a New BUG up its A$$ !! Again...
    By v488 in forum Bridgeport and Hardinge Mills
    Last Post: 05-26-2008, 02:55 PM
  5. V2XT Password
    By Riverside192 in forum Bridgeport and Hardinge Mills
    Last Post: 12-14-2006, 07:51 PM
