Old 09-07-2009, 03:00 AM
JBPS is on a distinguished road
TNC 2500 looses memory
Hi All,
I have a Bridgeport 720 with a TNC 2500 control, it keeps loosing memory/parameters as soon as it is turned off, I have replaced the backup batteries, but the problem persists, has anyone else had this problem? Or can anyone offer a solution?
Regards
Marc
Old 09-07-2009, 04:40 AM
Oopee is on a distinguished road
I had the same problem a while ago with Mikron+ tnc315. I cleaned the contact surfaces from dust and other s***, and it helped.
Osmo P
Caution for growing spindels
Old 09-07-2009, 05:02 AM
Many thanks, i'll give it a try!
Marc
Old 09-07-2009, 10:26 AM
rmarz is on a distinguished road
I'm not knowledgeable in this system so I offer this just as a guess. I would also recommend cleaning the backup battery terminals. Most battery back-up circuits use a diode to isolate the battery current from the powered system. You might try to locate that diode and check with an ohmmeter. Lastly, with the AC power off, check for battery current being provided to the system. Try to follow the circuit board traces from the + terminal of the battery.
Rick Marz
z axis looses position - like it jumps time jgriffith66 AjaxCNC Control Products 5 03-02-2009 12:23 AM
Fanuc 18i-T looses position when E-stop hit. Radish Machine Problems, Solutions , Wireless DNC, serial port 1 02-04-2008 11:53 AM
Lathemaster ZAY Looses Magic Smoke in Motor bill south Benchtop Machines 12 11-20-2007 09:28 PM
Caution - Mach Looses It's Mind bill south Mach Wizards, Macros, & Addons 4 01-08-2007 02:11 PM
X looses .002" per inch dmgdesigns DIY-CNC Router Table Machines 4 10-10-2005 02:33 PM
