Old 09-03-2009, 12:57 PM
ranchak is on a distinguished road
How Do I Load a Program?
How do I load G Code from Notepad into my Boss 5 memory? I know there must be a command in Notepad that I use to send the code to the Boss, is it Print?
Old 09-04-2009, 08:47 AM
Moderator
machintek is on a distinguished road
You need software such as PROCOMM, and the correct cable. There used to be a package of this on EBAY. Communication also enables a very powerful editor.
George
Old 09-04-2009, 02:48 PM
Thanks George, I ordered a BOB from Hillbilly. When I bought the mill the owner told me he programmed in notepad and then sent the G code to the mill. I couldn't figure out how that worked. Now I can use Mach 3.
I did get my wiring nightmare figured out, I am running the motor and servos on three phase through a VFD and the controls are running on single phase. Took awhile to get all of the wiring figured out, but I was able to use all of the original controls. Hopefully soon I will be able to make some parts.
Need Help!- FANUC 31i load program Bama Fanuc 1 04-18-2010 04:22 AM
Problem- Can't load program to Fanuc 21i-m dpy Machine Problems, Solutions , Wireless DNC, serial port 10 04-09-2009 06:18 AM
Need Help!- Can not load a program via MDI steelhead9 Fanuc 4 01-22-2009 11:31 AM
New user, program won't load. l u k e OneCNC 8 11-30-2008 09:52 AM
Doesnt load all of the program? dafowfidy Mach Mill 3 08-06-2008 09:00 PM
