Old 09-02-2009, 10:53 AM
dirtdiggler is on a distinguished road
Boss 9 spindle bearing
Hey guys,
I've been having some noise and heat coming from my varispeed head and my quill. I tore down my head and found one of the causes was a loose/worn bearing on the top part of my spindle (see picture). I can move the bearing side to side with my fingers.
What is the normal protocol for removing/installing this particular bearing? How do I get the nut off above the bearing, do I use a normal spanner tool?
Do I need to heat the bearing to get it off?
Any help would be appreciated.
ID:	87815   Click image for larger version
Old 09-02-2009, 11:18 AM
Hood is on a distinguished road
C Spanner like you would have for a collet chuck is what you need, if you dont have one then tap loose with a brass drift. The bearing will come off no problem, its a sliding fit.
Hood
Old 09-02-2009, 01:29 PM
Thanks Hood.
I just ordered the bearing and a hook spanner. Hopefully changing this bearing and the new bushings on my Vari-speed will smooth things out.
Cheers.
Old 09-02-2009, 01:31 PM
...one more thing: is it worth re-packing the two bearings on the bottom with new grease while I have the spindle out? The machine has been in my hands for about a year, before that I don't really know the history.
Old 09-02-2009, 04:44 PM
I think I would wash them out and repack, but not an expert on the subject.
Hood
Old 09-06-2009, 08:00 PM
NC Cams or any other bearing gurus please help!
Okay I have a few more questions...
I found an online dealer who sells the exact numbered bearing I need. I ordered one (it was $50.00) and when I recieved the bearing I noticed that the bearing cover on one side was slightly dented in, and the bearing has a tiny bit of side to side play in it (equal amount of wobble to old one). This is the slight amount of play can be felt when I push and pull horizontally on the spindle without the varispeed shives attached.
So my question is, does anybody know if this this particular bearing at the top of the spindle tends to have a tiny amount of play in it prior to being installed back in the head, or is it usually 100% tight out of the box when new?
Secondly, can I get away with using a regular FAFNIR 206KDD bearing instead of the FAFNIR M206KDD or will this result in craptastic results.
Any help would be appreciated!
-Kirk
BOSS Eight Spindle Bearing ID Jim Bass Bridgeport and Hardinge Mills 6 01-11-2009 07:04 PM
Need Help!- BP Series 1, was BOSS 5, need help tracking down BEARING and BELT replacement bbuonomo Bridgeport and Hardinge Mills 7 10-14-2008 10:20 PM
SL-30 spindle bearing CyberLung General Metal Working Machines 1 12-11-2007 08:59 PM
spindle bearing? ged Mechanical Calculations/Engineering Design 4 08-19-2007 09:22 PM
Air Bearing Spindle KBW DIY-CNC Router Table Machines 0 11-11-2003 09:44 AM
