Old 08-28-2009, 03:36 PM
hartan is on a distinguished road
Graphics in Bridgeport machine with HEIDENHAIN TNC 155
If I write a program, for example. something like:
%1003 G71
N10 G0 G40 G90
N20 G54 X-400 Y-150 Z-300
N21 G30 G17 X-20 Y-20 Z-10
N22 G31 G90 X20 Y20 Z0
N30 G99 T10 L130 R3,5
N40 G99 T11 L94 R1,5
N50 T10 G17 S1600
N60 G1 M6
N70 G0 X0 Y0 Z20 M13
N80 G1 Z0 F1000
N90 Z-2,5 F100
N100 G41 X12 Y0
N110 Y7,25
N120 X-12
N130 Y-7,25
N140 X12
N150 Y0
N160 G40 X0 Y0
N350 G0 Z150
N360 Y100
N370 M30
N9999 %1003 G71
Is the G-code is given correctly for the web graphics?
If I then press "MOD" and then choose for example. 3D display mode, and then give "START", my model does not do anything. Why?
Old 08-28-2009, 04:04 PM
gus gus is offline
gus is on a distinguished road
Not sure about G code, but you need a workpiece definition to get any graphics display on most of the controls. You might find a programming manual on their website
Old 08-29-2009, 08:35 AM
Workpiece definition is on line "N21" and "N22" (written in Bold). "G30" defines minimum of workpiese, and "G31" define maximum point of workpiese.
Old 08-29-2009, 04:02 PM
gridley51 is on a distinguished road
If you don`t already have it you can download the 155 programming manual from here.
https://filebase.heidenhain.de/doku/...40/N13F40.html
It defines the rules for graphics display
Old 08-30-2009, 05:39 AM
Thanks for the link, that I was looking for, but I did not find it.
Old 08-31-2009, 01:56 PM
Zhyyra is on a distinguished road
I suspect it may have something to do with your G54 (datum shift). Have you tried placing the G54 after the blank form definition (G30/31)?
Will you graphics show without the G54 in the program?
Old 09-05-2009, 02:55 AM
I will try to define the zero point after definition a piece. Maybe it will work. I will report.
Old 09-12-2009, 08:14 AM
I tried, but there is no difference.
Old 09-12-2009, 11:44 AM
DMIOM is on a distinguished road
.......If I then press "MOD" and then choose for example. 3D display mode, and then give "START", my model does not do anything. Why?
Can I just ask how you are trying to run it in graphics?
On our machine (TNC155B, but with a different actual machine tool, and in conversational mode) we use graphics quite a lot and very successfully. One trick (from the manual) is that you have to be in "run full program" or "run step" mode. Our sequence is :
1. Send program to TNC155B
2. If necessary, edit in edit mode
3. Press the button for 'Run full program'
4. Press program number and confirm you are in correct program
5. (if necessary) press [Goto] 0 (or whatever) to make sure you start from the beginning of the program
6. (if necessary) press [Mode] and select Iso-3 or 3D etc.
7. (if necessary) press [BlkForm] to get the blank workpiece displayed
8. Press the graphics [Start]
9. While it is running, there is a * next to the line number at the top of the screen
10. If there is no *, it is stopped either at the end of program, or waiting for a tool change? If it stops, just press the graphics [Start] again.
Dave
Old 09-13-2009, 08:59 AM
I will try according to your instructions. Thank you.
I'm interested in something ... There is any key to verify the correctness of the program? What does the "Program-test"? Found errors in the program?
  #11   Ban this user!
Old 09-14-2009, 04:12 AM
...... There is any key to verify the correctness of the program? What does the "Program-test"? Found errors in the program?
From the TNC155B manual we have:
"Before machining, the program can be subjected to a test for geometrical errors, without machine movement. The control calculates the program sequence as per a normal program run." (and also, just like a graphics run, it stops at every STOP and every tool change as well).
As we understand it, all this does is check that the machine doesn't think it has gone outside limits. Machine builders often set MP to their max, so this is only of any use if you manually set the MOD limits for XYZ each time - and it can't take any account of fixtures etc., nor does it know the whereabouts of the uncontrolled axis (e.g. knee). All we do is check it in PartMaster before we send it to the machine, then run it in graphics - but in both cases it is the human ("mark 1 eyeball" !) that is doing the real checking - I would never rely on the Program Test button to be definite that the program was safe (although if you're using Parametric programming, it could be a useful extra check).
Dave
  #12   Ban this user!
Old 09-15-2009, 03:50 PM
3. Press the 'Run full program'
'Run ful program' you mean press button for automatic?
That i do
That i do
That i do
That i do
If I have in the Auto mode, showing me * at the top of the screen on the left and is considered a lines. However, the model nothing happens. When come to the end of sentences, the model did not change.
As I mentioned, the model did not change. Although I came to the end of the program.
Bridgeport Interact 412/Heidenhain TNC 151 HELP? larrynsr Bridgeport and Hardinge Mills 15 08-30-2010 06:06 AM
Bridgeport Series 1 Heidenhain TNC 145 pestana1957 Bridgeport and Hardinge Mills 27 08-05-2009 06:13 PM
Need Help!- bridgeport textron heidenhain tnc 151 marcusppp Bridgeport and Hardinge Mills 2 03-03-2008 10:05 PM
bridgeport 2/heidenhain tnc145 Dar Bridgeport and Hardinge Mills 4 03-19-2007 09:05 PM
Looking for help for bridgeport/heidenhain 155 plane magic Bridgeport and Hardinge Mills 6 02-26-2007 08:00 PM
