Old 08-25-2009, 01:37 PM
dynamotive is on a distinguished road
Boss 5 power supply problems
I have the dreaded 70007 error code. I checked the logic voltages, and there is a serious problem there. Here’s what I got from the test points, top to bottom, with the digital voltmeter black lead in the GND jack:
-12 UR 17.27 (positive, not negative!)
-12 R -12.02
+12 UR 27.2
+12 R 12.03
GND +12 -.037
+5 UR 14.54
+5 R 4.98
GND +5 -.078
So, obviously, the UR part is screwed up. Anybody have any quick fixes, or things I should look at? I checked the fuses in the logic cabinet, but they all seem ok.
Old 08-25-2009, 08:54 PM
Moderator
machintek is on a distinguished road
The unregulated does not concern me.
There is a small terminal strip between the power supply and the logic card rack. There are 6 very thin wires there, 3 are blue and 3 are purple(?).
Put your meter across the center two, one blue and one purple, This is the 5VDC. I prefer to check the voltage here as it tells me what is at the logic boards. Go out one in each direction, I believe that is 12VDC and the last 2 are the -12VDC.
Adjust accordingly.But the 70007 usually means a LSI-11 (DEC KD11L ) motherboard problem.
George
Old 08-27-2009, 03:36 PM
Boss 5 problems
George: Thanks for the reply. I checked the voltages as you specified. The +/-12 looks ok, and the 5V was 4.93, which I assume is not far enough out to explain the problem. Looks like it's retrofit time.
Old 08-27-2009, 08:04 PM
Dyad1 is on a distinguished road
Hi Guys, We used to have several Boss 5 machines and one of them would always give the 70007 error on powerup. All we ever needed to do was flip the reset switch and everything was ok. The only time it would do this was on inital powerup and none of the other machines would. The Bridgeport tech told me this happened on some machines but I don't recall if he said why. We still have that machine although we don't use it now but I hooked up an extension cord to it to see if it would still error. It wound not. The only thing different now is we moved and now have 208 instead of 230 power. Maybe the voltage difference has something to do with it. When does your machine do this and will the reset switch cure the problem? Other than having to hit the reset the machine ran normal.
Good luck,
Gary
Old 08-28-2009, 11:07 AM
I have to correct the part about not doing it anymore. Tried again this morning and got the error. So much for different supply voltage.
Old 08-28-2009, 10:16 PM
Boss 5 problems
Very interesting. Some of the time, when I hit reset, the display goes to looking normal. And, often I can rapid a little bit. But, very soon, it won't rapid any more, and it seems dead.
Old 08-30-2009, 12:49 PM
creep_pea is on a distinguished road
Mine had this code too, I had to put another LS11 card in to get rid of it, I shortly after swapped to Mach3 and I would highly recommend doing the same if your struggling to find a replacement card, HillBilly on here supplies a BOB and good instructions to convert to mach very cheaply.
Problem- Power Supply Problems Grayling General Electronics Discussion 4 08-04-2008 07:18 PM
Bridgeport boss power supply sunsetmfg Bridgeport and Hardinge Mills 6 06-23-2007 03:31 PM
BP series 1 Boss 4 to EMC Gecko drive Power Supply retrofit arriflex Bridgeport and Hardinge Mills 3 10-06-2006 12:43 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
Bridgeport BOSS 6.2 56 volt DC power supply. Anyone know the current output of it. jstew0903 Bridgeport and Hardinge Mills 3 11-20-2005 09:41 PM
