How do you go about refinishing the ways on a chromed Axis's ways? My Y axis is worn through the chrome in the center of the travel. The prior owners didn't clean under the way covers I believe. Am I Up the creek or is it save-able? Thanks for any replies. Eric |
| I have seen the ways ground to remove the chrome and to create a virgin/true surface. To this was glued turcite and scraped in. George
| Despite the power tool, it is slow going, probably slower than hand scraping cast iron. Depending on where the saddle actually rides on the slide, it may not be a problem, depending on how wide the worn spot is. Jon |
| Thanks for the replies, I will have to figure out how bad it is. I know I tried planing some parts and I could not get the tram correct in different areas. basically If I got the tram correct at one end and moved to the other end, the tram would be out. I did adjust the gibs according to the manual (.0005" Deflection) Regards, Eric |
| Refinishing ways on Series 2 R2E3 | cut more | Bridgeport and Hardinge Mills | 2 | 12-11-2007 11:16 AM |
| Refinishing old machinist toolbox | ZipSnipe | WoodWorking | 7 | 07-22-2006 07:15 AM |
| First crack at scraping | MrRage | General Metal Working Machines | 11 | 03-09-2006 11:53 AM |
| More Scraping | MrRage | General Metal Working Machines | 1 | 01-14-2006 04:53 AM |
| Hand scraping | smallplanes | General Metal Working Machines | 12 | 12-27-2005 11:29 AM |
