Old 08-20-2009, 09:14 PM
Gncc50 is on a distinguished road
"m code not defined"
I am getting an error on my Powerpath 15. When I try to close chuck or open chuck with an M code through the aux functions. I get an error "M code not defined". It won't work with the foot pedal either. The tail stock extend isn't working either I get the same error. Earlier I was getting an error on the tailstock that said " option not installed". Some of the functions are working. Spindle on works. Any help would be appreciated.
Thanks, Pete
Old 08-21-2009, 07:30 AM
Moderator
machintek is on a distinguished road
Do you have the back up disks?
Sounds like you need to re-install the machine software and parameter file.
George
Old 08-21-2009, 04:19 PM
I was hoping I could avoid that, looks like that's what I am going to have to do.
Thanks,
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Need Help!- Heidenhain TNC2500 or TNC360 Teksoft Post Processor " G " code ISO RMARCH Bridgeport and Hardinge Mills 0 06-11-2009 11:51 AM
Newbie- Post adds "A0." code and machine stops lookingforhelp1 Fanuc 10 08-29-2008 12:58 PM
Newbie- Post adds "A0." code and machine stops lookingforhelp1 Post Processors for MC 2 08-29-2008 12:14 AM
"tool slot number too large" code dave6 Mach Mill 1 10-10-2006 05:57 PM
