Old 08-18-2009, 11:53 AM
richpsr is on a distinguished road
Bridgeport VMC 500 with Fanuc Series O-M
hi,
I am used to working SCM machines, through posts etc, and i have a basic programming knowledge, but this has stumped me.
I have got a bridgeport VMC miller and am having trouble inputtuing any MDI codes etc. I can jog the 3 axis with controls or the toggle wheel, but i cannot input code through MDI.
I have got the key turned horizontal (which is correct i believe) but as i have no manual I am scratching my head to be honest.
Has anyone out there got a programming manual, or could you give me a few pointers. I.e can you 'teach in' through the mdi?
Any help would be very gratefully received.
Rich.
Old 08-18-2009, 12:18 PM
stevo1 is on a distinguished road
When you are in MDI mode and start typing do the numbers appear at the bottom of the CRT? If so you should be able to type what you want say M3S100; then but a EOB and press insert or input. The code should then move to the top of the CRT which at this point you press cycle start to execute the code.
Have you tired it with the key in both positions?
PM me your email and I will send you over a manual.
Stevo
Bridgeport CNC Series 1 vs Series 2 jshank Bridgeport and Hardinge Mills 27 05-26-2012 08:51 AM
Series 2 cnc 2 hp motor on a series 1 bridgeport? CATCH22 Bridgeport and Hardinge Mills 1 11-08-2008 08:18 AM
Need Help!- Bridgeport Series 1 CNC Part2fix Bridgeport and Hardinge Mills 4 05-28-2008 04:02 PM
Bridgeport series 1 NC Machine Bridgeport and Hardinge Mills 3 05-22-2008 03:32 PM
Another Bridgeport Series 1 dougputt Bridgeport and Hardinge Mills 7 09-06-2007 06:46 PM
